Overriding Proration Factors
If the system logic for determining proration factors does not satisfy your requirements, you may plug in an override proration algorithm to calculate the proration factors as required by your implementation.
  • For Calculation Rule-Based Rates, the override proration algorithm is specified in the calculation rule’s business object.
  • For Component-Based Rates, the overriding proration algorithm is specified in the Installation record.
The system is delivered with an algorithm type that sets the proration factors to 1 (not applicable) when a predefined characteristic is specified on a calculation rule. Refer to OVPF-NOPROR for more information.
