Knowledge Base Articles
Once you have access to Oracle Support, finding Knowledge Base articles is an easy process.
- Log in to https://support.oracle.com.
 - Select the Knowledge tab at the top of the Oracle Support portal.
 - Under the Knowledge Base section, type "Oracle Utilities Meter Data Management" as the product.
 - Enter key search topics into the Enter search terms box.
 - Click Search.
The search results will display all knowledge articles stored on Oracle Support related to Oracle Utilities Meter Data Management for your key topics.
