Reviewing and Resolving Usage Transactions
This portal is used to review and/or resolve a Usage Transaction.
Refer to About Usage Transactions or About Usage Calculation for additional functional information.
You can access the portal from the Main > Usage > Usage Transaction. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Usage Transaction: Defines basic information about the usage transaction, including usage period date ranges, date breaks within the usage period, scalar usage details, and usage quantity details.
- Service Quantity Overlay: Displays interval data for each service quantity for the usage transaction's usage period
- Time of Use By Day: Displays TOU-mapped interval data by day for the usage transaction's usage period
A number of important actions are available for a Usage Transaction depending on its status:
 Action  |
 Allowed Statuses  |
 Details  |
 Approve  |
 Approval In Progress Issue Detected (only when the exceptions are marked to require approval)  |
 Allows a user to bypass any exception or failure message for the Usage Transaction and attempt to send it to the requesting system.  |
 Re-Calculate  |
 Approval In Progress Issue Detected  |
 Reruns the entire process of calculation along with any validations (all usage calculation rules) for the Usage Transaction.  |
 Subsequent Correction  |
 Sent  |
 Allows a user to indicate that the usage transaction was corrected after being sent. Sets the status of the usage transaction to Subsequent Correction.  |
 Resend  |
 Send Error  |
 Allows a user to re-send a usage transaction (via its related outbound message) to an external system. Used when an error occurs when sending usage transactions.  |
