Defining and Monitoring Statistics
Refer to Understanding Statistics for an overview of the statistics functionality.
To define and maintain statistics control records and view a list of the current snapshot records, open Admin > Reporting > Statistics Control.
This is an All-in-One portal and includes the standard List and display zones for a statistics control.
For information about the data defined on the statistics control, refer to embedded help.
Statistics Snapshot
If there are any Statistics Snapshot records for the statistics control, the Statistics Snapshot List zone displays a list of the most recent records. A user may drill into any of the records to view more detail. You are brought to a maintenance portal where you may view details about the calculated statistics. The information captured will be unique to the particular use case. Refer to the embedded help for more information.
