BO Algorithm Execution Summary
This table highlights the processing steps that occur when adding or changing a record that is governed by a business object.
| Invoke BO | |
| Event | Comments |
 BO Pre-processing algorithms executed  |
 These algorithms are only executed when Invoke BO is used. The business object in the Invoke BO is the one whose rules are executed.  |
| MO Processing | |
| Event | Comments |
 Determine if status has changed.  |
 The system keeps a note of the new status value but initially proceeds with the old value.  |
 MO Processing.  |
 Standard MO processing, including MO validation is executed.  |
 Determine BO algorithm executed.  |
 The MO level algorithm is executed to determine the identifying BO.  |
 BO Validation algorithms executed.  |
 State transition rules are performed if the status has changed.  |
 BO Status Exit algorithms for the “old” status executed.  |
 Status updated to the new value.  |
 BO Status Enter algorithms for the “new” status executed.  |
 If no error — MO Transition algorithms are executed. Fastpath: Refer to State Transitions are Audited for more information.
 If error and there are “save points” the MO Transition Error algorithms are executed. Fastpath: Refer to Keeping An Entity In Its Last Successful State for more information.
Otherwise, the error is reported.  |
 BO Status Monitor algorithms are executed.  |
 If the record transitions again, the prior step (State transition rule step) is repeated for the new transition.  |
 BO Post-processing algorithms are executed.  |
 BO Audit algorithms are executed.  |
 These algorithms are only executed if the system detects a change in elements that are not marked with “no audit”.  |
