Conversion Entities
Conversion is enabled for selected master and transaction maintenance objects. In the same way, only a subset of a maintenance object’s tables are enabled for conversion.
The following is provided for each maintenance object that supports conversion:
  • An entity validation batch control. This batch process validates data in staging and can also be run to validate data in production.
  • A key assignment batch control for each table that is eligible for conversion and has a system-generated key.
  • An XML resolution batch control if the maintenance object has at least one table that includes an XML storage field.
  • An insertion to production batch control for every table of the maintenance object that is eligible for conversion.
You may review the conversion configuration provided for an entity and more using the Conversion Entity Dashboard portal.
