Defining Configurations
You use the Configuration portal to display and maintain configurations.
You can access the portal by selecting Admin, then Configuration Report, then Configuration. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Configuration: This zone provides information about the selected configuration.
  • Configuration Attachments: This zone lists any attachments defined for the configuration.
