Maintaining Service Point Quantities
You use the Service Point Quantity portal to view and maintain service point quantities.
Refer to About Service Point Quantities for additional functional information.
You can access the portal from the Main > Device Installation > Service Point Quantity. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Service Point Quantity: This zone displays the basic attributes of the service point quantity
