Weather Insights
The Weather Insight module educates business customers on how changes in temperature can affect their energy use. It also provides a comparison between the current month's average temperature and the average temperature from the same month of the previous year. For example, "On average, this month was 13°F hotter than the same time last year."
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Options | Input Value |
Heading The default heading of the module varies depending on the state. These are the default headings by state:
Optional Choose one of the following:
Subheading The default subheading of the module varies depending on the state. These are the default headings by state:
Weather Insight Statement The default weather insight statement varies depending on the state. These are the default headings by state:
Fahrenheit or Celsius The weather insight temperature can be measured in degrees Fahrenheit or Celsius. Default: Fahrenheit |
User Experience Variations
This module can vary depending on how the temperature in the current period compares to the temperature in the comparison period from the previous year.
The weather insights calculation determines whether the average temperature was higher or lower between the current period and the comparison period. The calculator generates a weather insight that describes how weather might have impacted the bill's charges, and can result in the use of one of these states:
- Cooler
- Warmer
- Neutral
This section discusses how weather information is calculated to determine the module state.
Weather Data Collection
Weather information is collected for the following intervals:
- Current billing period: An uncompleted bill interval. The bill interval end date can be shifted up to 2 days and 4 hours due to a weather service latency (4 hours).
- Last year's billing period: 1 year shifted from the current billing period.
- Current season period: Last 30 days interval.
- Last year's season period: 1 year shifted from the current season period.
We classify each of the above periods into seasons: Heating, Cooling or Transition. The classification is made using average mean temperature.
Determine Whether Seasons are Comparable
Once the season classifications are calculated, we determine if the seasons are comparable. A comparable season is defined by two periods being either the same season or one period being defined as Transition.
To be comparable the following checks are made:
- current billing period and current season period (for example both must be "Heating", or both must be "Cooling", or one could be "Transition")
- current billing period and previous billing period
- current season period and previous season period
If one or more of the checks return a negative result, the seasons are not considered comparable. In this case, the module will not render in the communication.
Identifying the Weather Insight States
If the seasons are determined to be comparable, then the weather insight states are determined by the season classification and temperature difference calculations listed here:
- Warmer: If current billing period is classified as Cooling, the mean temperature difference between current bill period and previous bill period is positive, and the mean temperature difference is greater than 8˚F.
Note: For GAS service points, if any of the billing periods or season periods are classified as Cooling then the module will not render in the communication. This is because customers would not expect to use GAS during a Cooling season.
- Cooler: If current billing period is classified as Heating, the mean temperature difference between current bill period and previous bill period is negative, and the absolute mean temperature difference is greater than 8˚F.
- Neutral: If neither of the above criteria are met.
