Naming Convention
The naming convention for tablespace, partitions & subpartition is standardized as follows
• Each name consists of some or all of the following parts
• The parts of the name are organized hierarchically
• Each part of the Name is separated with an underscore.
• The maximum name length must not exceed 30 Characters.
• For an MO, the parent table and child table share the same tablespace for the corresponding partition (or sub partition as appropriate).
• Square brackets [ ] indicate that this part of the name should be omitted if not required.
OWNERFLAG_TABLEIDENTIFIER_PARTITIONNAME[_SUBPARTITIONNAME][_ARCHIVEFLAG][_COMPRESSFLAG]
For details on the convention, please refer to the table below:
Convention
Description
OWNERFLAG
Owner flag for the relevant application for example “C1” for CCB
TABLE
IDENTIFIER
The Index Name of the Primary Key index without the “P0” suffix. For example, if the PK index name is XT039P0, the table identifier would be “XT039”.
PARTITION
NAME
The Partition name should be prefixed with a P followed by a name which conforms to one of the following standards:
• 4 digit year and 3 letter month abbreviation PYYYYMON corresponding to the ILM date e.g. P2017JAN
• PMAX if it is the Max Value partition
SUBPARTITION
NAME
If subpartitions are used, name should be prefixed with S followed by a name of not more than 5 characters which conforms to the following requirements:
• SMAX if this is the Max Value sub partition
• If the sub partition holds data for a sub retention period use a number equal to that period e.g S91 if the sub retention period < 91 days.
• For a range based SubPartition on Primary Key, use an integral number increasing by +1. For example, if there are 8 sub partitions use S01 through S08
ARCHIVEFLAG
This flag is used as a suffix to the table and tablespace name for the staging tables created for the archiving operation.
• ARC
COMPRESS
FLAG
This flag is used as a suffix to the tablespace name for the staging tables created when compressing a partition.
• C
For compression related tasks, this is used as suffix to the tablespace name.
• Partition Tablespace Name: It is formed by OWNERFLAG_TABLEIDENTIFIER_PARTITIONNAME.
For example:
CM_D1T304_PMAX CM_D1T304_P2017JAN
• SubPartition Tablespace Name: It is formed by OWNERFLAG_TABLEIDENTIFIER_PARTITIONNAME_SUBPARTITIONNAME.
For example:
CM_D1T304_PMAX_SMAX
CM_D1T304_P2017JAN_SMAX
CM_D1T304_PMAX_S001
CM_D1T304_P2017JAN_S181
• Archive Staging Table And Its Tablespace Name (When archiving partition): It is formed by OWNERFLAG_TABLEIDENTIFIER_PARTITIONNAME_ ARCHIVEFLAG.
For example:
CM_D1T304_P2017JAN_ARC
• Archive Staging Table And Its Tablespace Name (When archiving subpartition): It is formed by OWNERFLAG_TABLEIDENTIFIER_PARTITIONNAME_SUBPARTITIONNAME_ ARCHIVEFLAG.
For example:
CM_D1T304_P2017JAN_S181_ARC
• Compressed Tablespace name (When compressing partition):
For example:
CM_D1T304_P2017JAN_ C
Module Specific ILM Implementation Details
This section outlines each maintenance object that has been configured to support ILM. The parent table is noted. Other tables are child tables of the parent unless otherwise noted. In each case, the partitioning strategy is indicated.
All indexes are listed with a recommendation whether the index should be global or local and whether the index should be partitioned. In addition to the base delivered indexes, each parent table includes a recommended ILM specific local index to build with the ILM_DT, ILM_ARCH_SW and the primary key of the table. The recommended column that should be used to populate the ILM_DT is also shown. Refer to Sample SQL For Enabling ILM in CCB (Existing Installation) for sample DDL(s).
The following maintenance tables are included:
• Bill
• Case
To Do Entry
This table describes the To Do Entry maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_TD_
ENTRY
(Parent)
RANGE (ILM_DT,
TD_ENTRY_
ID)
RANGE
(TD_ENTRY_
ID)
CI_TD_ENTRY.CRE_DTTM
XT039P0
TD_ENTRY_ID
Global
Partitioned
XT039S2
ASSIGNED_TO,
TD_ENTRY_ID
Global
XT039S3
ENTRY_STATUS_
FLG,
ASSIGNED_TO
Global
XT039S4
ROLE_ID, TD_TYPE_CD, ENTRY_STATUS_
FLG, TD_PRIORITY_FLG, ASSIGNED_TO, CRE_DTTM
Global
XT039S5
BATCH_CD,
BATCH_NBR,
ENTRY_STATUS_FLG
Global
XT039S6
TD_ENTRY_ID,
ASSIGNED_TO,
ENTRY_STATUS_FLG
Global
XT039S7
COMPLETE_USER_ID,
COMPLETE_DTTM,
TD_ENTRY_ID
Global
CM_ILM_XT039S8
ILM_DT, ILM_ARCH_SW,
TD_ENTRY_ID
Local
Partitioned
CI_TD_
ENTRY_CHA
Reference Partitioning
XT701P0
TD_ENTRY_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
XT701S1
SRCH_CHAR_VAL,
CHAR_TYPE_CD,
TD_ENTRY_ID
Global
XT701S2
CHAR_VAL_FK1
Global
CI_TD_
DRLKEY
XT037P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
XT037S1
KEY_VALUE,
TD_ENTRY_ID
Global
CI_TD_LOG
XT721P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
XT721S1
LOG_DTTM,USER_ID,
LOG_TYPE_FLG,
TD_ENTRY_ID
Global
CI_TD_MSG_
PARM(
Child table of CI_TD_LOG)
XT040P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
CI_TD_
SRTKEY
XT041P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
XT041S1
KEY_VALUE,
TD_ENTRY_ID
Global
Sync Request (Outbound)
This table describes the Sync Request (Outbound) maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_SYNC_
REQ(Parent)
RANGE (ILM_DT, F1_SYNC_
REQ_ID)
RANGE
(F1_SYNC_REQ_ID)
F1_SYNC_REQ.CRE_DTTM
F1T014P0
F1_SYNC_REQ_ID
Global Partitioned
F1T014S1
BO_STATUS_CD,
BUS_OBJ_CD,
F1_SYNC_REQ_ID
Global
F1T014S2
BO_STATUS_
REASON_CD
Global
F1T014S3
MAINT_OBJ_CD, PK_VALUE1,
PK_VALUE2,
F1_SYNC_REQ_ID
Global
CM_ILM_F1T014S4
ILM_DT,
ILM_ARC_SW,
F1_SYNC_REQ_ID
Local
Partitioned
F1_SYNC_REQ_CHAR
F1T017P0
F1_SYNC_REQ_ID,
CHAR_TYPE_CD, SEQ_NUM
Global Partitioned
F1T017S1
SRCH_CHAR_VAL
Global
F1_SYNC_REQ_EXTRACT
F1T019P0
F1_SYNC_REQ_ID,
SEQ_NUM
Global Partitioned
F1_SYNC_REQ_LOG
F1T015P0
F1_SYNC_REQ_ID,
SEQNO
Global Partitioned
F1T015S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T015S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1T015S3
BO_STATUS_REASON_CD
Global
F1_SYNC_REQ_LOG_
PARM(Child Table of F1_SYNC_REQ_LOG_
PARM)
F1T016P0
F1_SYNC_REQ_ID,
SEQNO,
PARM_SEQ
Global Partitioned
Note: It is recommended that data retention policies and rules for this object match the policies and rules implemented for the Inbound Sync Request on the target system to avoid data inconsistencies when auditing.
This table describes the Inbound Sync Request maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_SYNC_REQ_IN
(Parent)
RANGE(ILM_DT, F1_SYNC_REQ_IN_ID)
RANGE
(F1_SYNC_REQ_IN_ID)
F1_SYNC_REQ_IN.CRE_DTTM
F1T191P0
F1_SYNC_REQ_
IN_ID
Global Partitioned
F1T191S1
BO_STATUS_CD,
BUS_OBJ_CD,
F1_SYNC_REQ_
IN_ID
Global
F1T191S2
MAINT_OBJ_CD, EXT_PK_VALUE1, NT_XID_CD, PK_VALUE1
Global
F1T191S3
EXT_REFERENCE_ID
Global
CM_ILM_F1T191S3
F1_SYNC_REQ_IN_ID
Local
Partitioned
F1_SYNC_REQ_
IN_CHAR
F1T193P0
F1_SYNC_REQ_IN_ID, CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1T193S1
SRCH_CHAR_VAL
Global
F1_SYNC_REQ_
IN_EXCP
F1T197P0
F1_SYNC_REQ_IN_ID, SEQNO
Global Partitioned
F1_SYNC_REQ_
IN_EXCP_PARM
(Child Table of F1_SYNC_REQ_IN_EXCP)
F1T198P0
F1_SYNC_REQ_IN_ID, SEQNO,
PARM_SEQ
Global Partitioned
F1_SYNC_REQ_
IN_LOG
F1T194P0
Global Partitioned
F1T194S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T194S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1_SYNC_REQ_IN_LOG_PARM
(Child Table of F1_SYNC_REQ_IN_LOG)
F1T195P0
F1_SYNC_REQ_IN_ID,
SEQNO, PARM_SEQ
Global Partitioned
F1_SYNC_REQ_IN_REL_OBJ
F1T192P0
F1_SYNC_REQ_IN_ID, MAINT_OBJ_CD, REL_OBJ_TYPE_FLG
Global Partitioned
F1T192S1
PK_VALUE1
Global
Note: It is recommended that data retention policies and rules for this object match the policies and rules implemented for the Outbound Sync Request on the source system to avoid data inconsistencies when auditing.
Outbound Message
This table describes the Outbound Message maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_OUTMSG
(Parent)
RANGE (ILM_DT,
OUTMSG_ID)
RANGE (OUMSG_ID)
F1_OUTMSG.
CRE_DTTM
FT010P0
OUTMSG_ID
Global
Partitioned
FT010S1
OUTMSG_STATUS_FLG, OUTMSG_TYPE_CD
Global
CM_ILM_
FT010S2
ILM_DT, ILM_ARC_SW,
OUTMSG_ID
Local
Partitioned
F1_OUTMSG_
ERRPARM
FT011P0
OUTMSG_ID, PARM_SEQ
Global
Partitioned
Service Task
This table describes the Service Task maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_SVC_TASK
(Parent)
RANGE (ILM_DT, F1_SVC_TASK_ID)
RANGE (F1_SVC_TASK_
ID_)
F1_SVC_TASK.
CRE_DTTM
F1C474P0
F1_SVC_TASK_ID
Global
Partitioned
F1C474S1
F1_STASK_TYPE_CD
Global
F1C474S2
BUS_OBJ_CD
Global
CM_ILM_F1C474S3
ILM_DT, ILM_ARC_SW,
F1_SVC_TASK_ID
Local
Partitioned
F1_SVC_TASK_
CHAR
F1C476P0
F1_SVC_TASK_ID, CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1C476S1
SRCH_CHAR_VAL
Global
F1_SVC_TASK_
LOG
F1C477P0
F1_SVC_TASK_ID,
SEQNO
Global Partitioned
F1C477S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1C477S2
CHAR_TYPE_CD, CHAR_VAL
Global
F1_SVC_TASK_
LOG_PARM
(Child Table of F1_SVC_TASK_
LOG)
F1C478P0
F1_SVC_TASK_ID, SEQNO,
PARM_SEQ
Global Partitioned
F1_SVC_TASK_
REL_OBJ
F1C479P0
F1_SVC_TASK_ID,
MAINT_OBJ_CD,
SEQ_NUM
Global Partitioned
F1C479S1
MAINT_OBJ_CD,
PK_VALUE1,
PK_VALUE2,
PK_VALUE3
PK_VALUE4
PK_VALUE5
Global
Object Revision
This table describes the Object Revision maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_OBJ_REV
(Parent)
RANGE (ILM_DT, REV_ID)
RANGE (REV_ID)
F1_OBJ_REV. STATUS_UPD_DTTM
FT035P0
REV_ID
Global
Partitioned
FT035S1
BO_STATUS_CD,
BUS_OBJ_CD,
REV_ID
Global
FT035S2
MAINT_OBJ_CD,
PK_VALUE1
Global
FT035S3
EXT_REFERENCE_ID,
MAINT_OBJ_CD
Global
FT035S4
USER_ID,
MAINT_OBJ_CD
Global
FT035S5
PK_VALUE1
Global
CM_ILM_
FT035S6
ILM_DT,
ILM_ARC_SW,
REV_ID
Local
Partitioned
F1_OBJ_REV_
CHAR
FT037P0
REV_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
FT037S1
SRCH_CHAR_VAL
Global
F1_OBJ_REV_
LOG
FT039P0
REV_ID, SEQNO
Global Partitioned
F1_OBJ_REV_
LOG_PARM
(Child Table of F1_OBJ_REV_
LOG)
FT040P0
REV_ID, SEQNO, PARM_SEQ
Global Partitioned
Note: This maintenance object is enabled for ILM, however it is not used in a production environment. It is typically used in a development or configuration environment. Your implementation should review its use of this functionality and consider whether or not it is a candidate for ILM and in which region.
Object Erasure
This table describes the Object Erasure maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_ERASURE_SCHED (Parent)
RANGE (ILM_DT, ERASURE_
SCHED_ID)
F1_ERASURE_
SCHED. STATUS_UPD_
DTTM.
F1T756P0
ERASURE_
SCHED_ID
GLOBAL Partitioned
RANGE (ERASURE_
SCHED_ID)
CM_ILM_
F1T756S1
ILM_DT, ILM_ARCH_SW, ERASURE_
SCHED_ID
LOCAL Partitioned
F1_ERASURE_SCHED_
LOG
Reference partitioning
F1T757P0
ERASURE_SCHED_ID, SEQNO
GLOBAL Partitioned
F1_ERASURE_SCHED_
LOG_PARM
F1T758P0
ERASURE_SCHED_ID, SEQNO, PARM_SEQ
GLOBAL Partitioned
Process Flow
This table describes the Process Flow maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_PROC_
STORE (Parent)
RANGE (ILM_DT, PROC_STORE_
ID)
F1_PROC_STORE.
STATUS_UPD_DTTM.
F1T747P0
PROC_STORE_ID
GLOBAL Partitioned
RANGE (PROC_STORE_ID)
CM_ILM_ F1T747S1
ILM_DT, ILM_ARCH_
SW, PROC_STORE_ID
LOCAL Partitioned
F1_PROC_STORE_DTL_
ELEMENTS
F1T748P0
PROC_
STORE_ID, CHAR_TYPE_CD, SEQ_NUM
GLOBAL Partitioned
F1_PROC_STORE_LOG
F1T749P0
PROC_STORE_ID, SEQNO
GLOBAL Partitioned
F1_PROC_STORE_LOG_
PARM
F1T750P0
PROC_STORE_ID, SEQNO, PARM_SEQ
GLOBAL Partitioned
Adjustment
This table describes the Adjustment maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_ADJ
(Parent)
RANGE (ILM_DT,
ADJ_ID)
RANGE (ADJ_ID)
CI_ADJ.CRE_DT
XT012P0
ADJ_ID
Global
Partitioned
XT012S1
SA_ID, ADJ_TYPE_CD
Global
XT012S2
XFER_ADJ_ID, ADJ_ID
Global
XT012S4
APPR_REQ_ID, ADJ_ID
Global
CM_ILM_
XT012S3
ILM_DT, ILM_ARCH_SW, ADJ_ID
Local
Partitioned
CI_ADJ_APREQ
XT160P0
AP_REQ_ID
Global
XT160S1
ADJ_ID
Global
XT160S2
BATCH_CD, BATCH_NBR
Global
CI_ADJ_CALC_
LN
XT310P0
ADJ_ID, SEQNO
Global
Partitioned
CI_ADJ_CL_
CHAR
XT309P0
ADJ_ID,
SEQNO, CHAR_TYPE_
CD
Global
Partitioned
CI_ADJ_CHAR
XC781P0
ADJ_ID, CHAR_TYPE_
CD,
SEQ_NUM
Global
Partitioned
XC781S1
SRCH_CHAR_
VAL
Global
Approval Request
This table describes the Approval Request maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_APPR_REQ (Parent)
RANGE (ILM_DT, APPR_REQ_ID)
RANGE (APPR_REQ_ID)
MIN(LOG_DTTM) on CI_APPR_REQ_LOG for given APPR_REQ_ID
XT600P0
APPR_REQ_ID
Global
Partitioned
CM_ILM_
XT600S1
ILM_DT, ILM_ARCH_SW, APPR_REQ_ID
Local
partitioned
CI_APPR_REQ_CHAR
XT601P0
APPR_REQ_ID, CHAR_TYPE_CD, SEQ_NUM
Global
Partitioned
XT601S1
SRCH_CHAR_
VAL
Global
CI_APPR_REQ_LOG
XT602P0
APPR_REQ_ID, SEQNO
Global
Partitioned
XT602S1
CHAR_TYPE_
CD, CHAR_VAL_FK1
Global
CI_APPR_REQ_LOG_PARM
XT603P0
APPR_REQ_ID, SEQNO, PARM_SEQ
Global
Partitioned
Bill
This table describes the Bill maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_BILL (Parent)
RANGE (ILM_DT, BILL_ID)
RANGE (BILL_ID)
CI_BILL.CRE_DTTM
XT033P0
BILL_ID
Global
Partitioned
XT033S1
ACCT_ID, BILL_STAT_
FLG, BILL_CYC_CD, WIN_START_DT,CR_NOTE_FR_BILL_ID
Global
XT033S2
CR_NOTE_FR_
BILL_ID, BILL_ID
Global
XT033S3
ALT_BILL_ID, BILL_STAT_
FLG, BILL_ID
Global
XT033S4
OFFCYC_BGEN_ID, BILL_ID
Global
XT033S5
DOC_ID, DOC_TYPE_
FLG, BILL_STAT_FLG, BILL_ID
Global
CM_ILM_
XT033S6
ILM_DT, ILM_ARCH_SW, BILL_ID
Local
Partitioned
XT033S7
ACCT_ID, OFFCYC_BGEN_ID, CRE_DTTM
Global
XT033S8
LATE_PAY_
CHARGE_SW, LATE_PAY_
CHARGE_DT, BILL_ID
Global
CI_BILL_CHAR
XT313P0
BILL_ID, CHAR_TYPE_
CD, SEQ_NUM
Global
Partitioned
XT313S1
SRCH_CHAR_
VAL
Global
CI_BILL_EXCP
XT038P0
BILL_ID
Global
Partitioned
CI_BILL_MSGS
XT091P0
BILL_ID, BILL_MSG_CD
Global
Partitioned
CI_BILL_MSG_
PRM
XT085P0
BILL_ID, BILL_MSG_CD, SEQ_NUM
Global
Partitioned
CI_BILL_SA
XT046P0
BILL_ID, SA_ID
Global
Partitioned
XT046S1
SA_ID
Global
CI_BILL_
ROUTING
XT075P0
BILL_ID, SEQNO
Global
Partitioned
XT075S1
BATCH_CD, BATCH_NBR, BILL_ID, NO_BATCH_
PRT_SW
Global
Bill Segment
This table describes the Bill Segment maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_BSEG (Parent)
RANGE (ILM_DT, BSEG_ID)
RANGE (BSEG_ID)
CI_BSEG.CRE_DTTM
XT048P0
BSEG_ID
Global
Partitioned
XT048S1
BILL_ID
Global
XT048S2
SA_ID
Global
XT048S3
QUOTE_DTL_
ID, BSEG_ID
Global
CM_ILM_
XT048S4
ILM_DT, ILM_ARCH_SW, BSEG_ID
Local
Partitioned
CI_BSEG_CALC
XT072P0
BSEG_ID, HEADER_SEQ
Global
Partitioned
XT072S1
BILLABLE_CHG_ID, BSEG_ID
Global
CI_BSEG_CALC_LN
XT050P0
BSEG_ID, HEADER_SEQ, SEQNO
Global
Partitioned
CI_BSEG_CL_
CHAR
XT056P0
BSEG_ID, HEADER_SEQ, SEQNO, CHAR_TYPE_
CD
Global
Partitioned
CI_BSEG_EXCP
XT051P0
BSEG_ID
Global
Partitioned
CI_BSEG_MSG
XT080P0
BSEG_ID, BILL_MSG_CD
Global
Partitioned
CI_BSEG_READ
XT054P0
BSEG_ID, SP_ID, SEQNO
Global
Partitioned
XT054S1
SP_ID
Global
XT054S2
START_REG_READ_ID
Global
XT054S3
END_REG_
READ_ID
Global
CI_BSEG_SQ
XT055P0
BSEG_ID, UOM_CD, TOU_CD, SQI_CD
Global
Partitioned
CI_BSEG_ITEM
XT053P0
BSEG_ID, SEQNO
Global
Partitioned
Statement
This table describes the Statement maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_STM (Parent)
RANGE (ILM_DT, STM_ID)
RANGE (STM_ID)
CI_STM.STM_DT
XT088P0
STM_ID
Global
Partitioned
CM_ILM_
XT088S1
ILM_DT, ILM_ARCH_SW, STM_ID
Local
Partitioned
CI_STM_DTL
XT119P0
STM_DTL_ID
Global
XT119S1
STM_ID
Global
Off Cycle Bill Generator
This table describes the Off Cycle Bill Generator maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_OFFCYC_
BGEN (Parent)
RANGE (ILM_DT, OFFCYC_
BGEN_ID)
RANGE (OFFCYC_BGEN_ID)
C1_OFFCYC_BGEN.STATUS_UPD_DTTM
XT197P0
OFFCYC_BGEN_ID
Global
Partitioned
XT197S1
ACCT_ID
Global
CM_ILM_
XT197S2
ILM_DT, ILM_ARCH_SW, OFFCYC_BGEN_ID
Local
Partitioned
C1_OFFCYC_BGEN_ADJ
XT285P0
OFFCYC_BGEN_ID, ADJ_ID
Global
Partitioned
XT285S1
ADJ_ID
Global
C1_OFFCYC_BGEN_BCHG
XT326P0
OFFCYC_BGEN_ID, BILLABLE_
CHG_ID
Global
Partitioned
XT326S1
BILLABLE_CHG_ID
Global
C1_OFFCYC_BGEN_CHAR
XT343P0
OFFCYC_BGEN_ID, CHAR_TYPE_
CD, SEQ_NUM
Global
Partitioned
XT343S1
SRCH_CHAR_
VAL
Global
C1_OFFCYC_BGEN_LOG
XT344P0
OFFCYC_BGEN_ID, SEQNO
Global
Partitioned
XT344S1
CHAR_TYPE_
CD, CHAR_VAL_FK1
Global
C1_OFFCYC_BGEN_LOG_PARM
XT357P0
OFFCYC_BGEN_ID, SEQNO, PARM_SEQ
Global
Partitioned
C1_OFFCYC_BGEN_SA
XT359P0
OFFCYC_BGEN_ID, SA_ID
Global
Partitioned
XT359S1
SA_ID
Global
Billable Charge
This table describes the Billable Charge maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_BILL_CHG (Parent)
RANGE (ILM_DT, BILLABLE_CHG_ID)
RANGE (BILLABLE_CHG_ID)
CI_BILL_CHG.START_DT
XT035P0
BILLABLE_CHG_ID
Global
Partitioned
XT035S1
SA_ID
Global
CM_ILM_
XT035S2
ILM_DT, ILM_ARCH_SW, BILLABLE_CHG_ID
Local
Partitioned
CI_BCHG_READ
XT271P0
BILLABLE_CHG_ID, SP_ID, SEQNO
Global
Partitioned
CI_BCHG_SQ
XT081P0
BILLABLE_CHG_ID, SEQ_NUM
Global
Partitioned
CI_B_CHG_
LINE
XT001P0
BILLABLE_CHG_ID, LINE_SEQ
Global
Partitioned
CI_B_LN_CHAR
XT083P0
BILLABLE_CHG_ID, LINE_SEQ, CHAR_TYPE_
CD
Global
Partitioned
Case
This table describes the Case maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_CASE (Parent)
RANGE (ILM_DT, CASE_ID)
RANGE (CASE_ID)
MIN(LOG_DTTM) on CI_CASE_LOG table for given CASE_ID
XT220P0
CASE_ID
Global
Partitioned
XT220S1
PER_ID
Global
XT220S2
ACCT_ID
Global
XT220S3
PREM_ID
Global
XT220S4
USER_ID
Global
CM_ILM_
XT220S5
ILM_DT, ILM_ARCH_SW, CASE_ID
Local
Partitioned
CI_CASE_CHAR
XT222P0
CASE_ID, CHAR_TYPE_
CD, SEQ_NUM
Global
Partitioned
XT222S1
SRCH_CHAR_
VAL
Global
CI_CASE_LOG
XT221P0
CASE_ID, SEQ_NUM
Global
Partitioned
XT221S1
CHAR_TYPE_
CD, CHAR_VAL_FK1
Global
CI_CASE_LOG_PARM
XT290P0
CASE_ID, SEQ_NUM, PARM_SEQ
Global
Partitioned
Field Activity
This table describes the Field Activity maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_FA (Parent)
RANGE (ILM_DT, FA_ID)
RANGE (FA_ID)
CI_FA.CRE_
DTTM
XT094P0
FA_ID
Global
Partitioned
XT094S1
SP_ID, FO_ID
Global
XT094S2
FO_ID, FA_ID
Global
XT094S3
FA_STATUS_
FLG, ELIG_
DISPATCH_SW, FO_ID, FA_ID
Global
XT094S4
APP_SCHED_ID, FA_ID
Global
XT094S5
TEST_SEL_ID, FA_ID
Global
CM_ILM_
XT094S6
ILM_DT, ILM_ARCH_SW, FA_ID
Local
Partitioned
XT094S7
FA_EXT_ID, FA_ID
Global
CI_FA_CHAR
XT406P0
FA_ID, CHAR_TYPE_
CD, SEQ_NUM
Global
Partitioned
XT406S1
SRCH_CHAR_
VAL
Global
CI_FA_LOG
XT350P0
FA_ID, SEQ_NUM
Global
Partitioned
CI_FA_REM
XT407P0
FA_ID, FA_REM_CD
Global
Partitioned
CI_FA_REM_
EXC
XT312P0
FA_ID, FA_REM_CD
Global
Partitioned
CI_FA_REM_
EXP
XT405P0
FA_ID, FA_REM_CD, PARM_SEQ
Global
Partitioned
CI_FA_STEP
XT095P0
FA_ID, STEP_SEQ_NBR
Global
Partitioned
XT095S1
CC_ID
Global
XT095S2
SPAWNED_FA_
ID, FA_ID
Global
XT095S3
MR_ID
Global
Enrollment (Order)
This table describes the Enrollment (Order) maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_ENRL (Parent)
RANGE (ILM_DT, ENRL_ID)
RANGE (ENRL_ID)
CI_ENRL.
START_DT
XT193P0
ENRL_ID
Global
Partitioned
XT193S1
PER_ID
Global
XT193S2
ACCT_ID
Global
XT193S3
PREM_ID
Global
CM_ILM_XT193S4
ILM_DT, ILM_ARCH_SW, ENRL_ID
Local
Partitioned
CI_ENRL_ADDR
XT200P0
ENRL_ID, ENRL_ADDR_
ENT_FLG
Global
Partitioned
XT200S1
ADDRESS1_UPR, ENRL_ID
Global
XT200S2
CITY_UPR, ENRL_ID
Global
CI_ENRL_FLD
XT191P0
ENRL_ID, SEQ_NUM
Global
Partitioned
CI_ENRL_LOG
XT198P0
ENRL_ID, SEQ_NUM
Global
Partitioned
CI_ENRL_PER_
ID
XT199P0
ENRL_ID, ID_TYPE_CD
Global
Partitioned
XT199S1
HASH_PER_ID_NBR, ENRL_ID, ID_TYPE_CD
Global
CI_ENRL_PER_NM
XT194P0
ENRL_ID, SEQ_NUM
Global
Partitioned
XT194S1
ENTITY_NAME_UPR, ENRL_ID
Global
CI_ENRL_PER_PHN
XT195P0
ENRL_ID, SEQ_NUM
Global
Partitioned
C1_ENRL_CONTDET
C1T011S1
C1_ENRL_CONTACT_ID
Global Partitioned
Payment Event
This table describes the Payment Event maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_PAY_EVENT (Parent)
RANGE (ILM_DT, PAY_EVENT_
ID)
RANGE (PAY_EVENT_
ID)
CI_PAY_EVENT.PAY_DT
XT159P0
PAY_EVENT_ID
Global Partitioned
XT159S1
PAY_DT, PAY_EVENT_ID
Global
XT159S2
DOC_ID, PAY_EVENT_ID
Global
CM_ILM_XT159S3
ILM_DT, ILM_ARCH_SW, PAY_EVENT_ID
Local
Partitioned
CI_PAY_EVT_CHAR
XT244P0
PAY_EVENT_ID, CHAR_TYPE_CD, SEQ_NUM
Global
Partitioned
XT244S1
SRCH_CHAR_VAL
Global
CI_PAY_EVT_EXCP
XT161P0
PAY_EVENT_ID
Global
Partitioned
CI_PAY_TNDR
XT265P0
PAY_TENDER_ID
Global
XT265S1
MICR_ID
Global
XT265S2
TENDER_AMT, PAY_TENDER_ID
Global
XT265S3
PAY_EVENT_ID
Global
XT265S4
PAYOR_ACCT_
ID, TENDER_AMT
Global
XT265S5
TNDR_CTL_ID, PAY_EVENT_ID
Global
XT265S6
ADJ_ID
Global
XT265S7
HASH_MICR_ID, PAY_TENDER_
ID
Global
CI_APAY_CLR_STG
XT003P0
APAY_CLR_ID
Global
XT003S1
BILL_ID
Global
XT003S2
PAY_TENDER_ID
Global
XT003S3
BATCH_CD, BATCH_NBR, SCHED_EXTRACT_DT
Global
XT003S4
ACCT_APAY_ID
Global
CI_PAY_TNDR_CHAR
XT413P0
PAY_TENDER_ID, CHAR_TYPE_CD, SEQ_NUM
Global
XT413S1
SRCH_CHAR_VAL
Global
CI_PEVT_DST_DTL
XT730P0
PAY_EVENT_ID, SEQ_NUM
Global
Partitioned
XT730S1
SRCH_CHAR_VAL
Global
Payment
This table describes the Payment maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_PAY (Parent)
RANGE (ILM_DT, PAY_ID)
RANGE (PAY_ID)
CI_PAY_EVENT.PAY_DT
XT156P0
PAY_ID
Global
Partitioned
XT156S1
ACCT_ID
Global
XT156S2
PAY_EVENT_ID
Global
XT156S3
PAY_AMT, PAY_ID
Global
CM_ILM_
XT156S4
ILM_DT, ILM_ARCH_SW, PAY_ID
Local
Partitioned
CI_PAY_CHAR
XT412P0
PAY_ID, CHAR_TYPE_
CD, SEQ_NUM
Global
Partitioned
XT412S1
SRCH_CHAR_VAL
Global
CI_PAY_EXCP
XT163P0
PAY_ID
Global
Partitioned
CI_PAY_SEG
XT165P0
PAY_SEG_ID
Global
XT165S1
PAY_ID
Global
XT165S2
SA_ID
Global
Match Event
This table describes the Match Event maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_MATCH_EVT (Parent)
RANGE (ILM_DT, MATCH_EVT_ID)
RANGE (MATCH_EVT_
ID)
CI_MATCH_EVT.CREATE_DT
XT266P0
MATCH_EVT_ID
Global
Partitioned
XT266S1
ACCT_ID,
MEVT_STATUS_FLG
Global
XT266S2
PAY_ID
Global
CM_ILM_
XT266S3
ILM_DT,
ILM_ARCH_SW,
MATCH_EVT_
ID
Local
Partitioned
Usage Request
This table describes the Usage Request maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_USAGE (Parent)
RANGE (ILM_DT, USAGE_ID)
RANGE (USAGE_ID)
C1_USAGE.CRE_DTTM
CT368S2
BSEG_ID
Global
CT368S3
USER_ID, USAGE_ID
Global
XT368P0
USAGE_ID
Global
Partitioned
XT368S1
BUS_OBJ_CD,BO_STATUS_CD,
WIN_START_DT,
BILL_CYC_CD,
USAGE_ID
Global
CT368S2
BSEG_ID
CT368S3
USER_ID,
USAGE_ID
XT368S4
SA_ID
Global
CT368S4
MASTER_USAGE_ID
CT368S5
SA_REL_ID
CM_ILM_
XT368S5
ILM_DT,
ILM_ARCH_SW,
USAGE_ID
Local
Partitioned
C1_USAGE_
CHAR
XT387P0
USAGE_ID,
CHAR_TYPE_
CD,
SEQ_NUM
Global
Partitioned
XT387S1
SRCH_CHAR_
VAL
Global
C1_USAGE_LOG
XT388P0
USAGE_ID,
SEQNO
Global
Partitioned
XT388S1
CHAR_TYPE_
CD,
CHAR_VAL_FK1
Global
C1_USAGE_LOG_PARM
XT389P0
USAGE_ID,
SEQNO,
PARM_SEQ
Global
Partitioned
Business Flag
This table describes the Business Flag maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_BUS_FLG
(Parent)
RANGE (ILM_DT,BUS_FLG_ID)
RANGE(BUS_FLG_ID)
F1_BUS_FLG.
CRE_DTTM
F1T681P0
BUS_FLG_ID
Global Partitioned
F1T681S1
BUS_OBJ_CD,
BO_STATUS_CD,
BUS_FLG_ID
Global
CM_ILM_
F1T681S2
ILM_DT,
ILM_ARCH_SW,
BUS_FLG_ID
Local Partitioned
F1_BUS_FLG_
CHAR
F1T684P0
BUS_FLG_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1T684S0
SRCH_CHAR_VAL
Global
F1_BUS_FLG_
LOG
F1T685P0
BUS_FLG_ID,
SEQNO
Global Partitioned
F1T685S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T685S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1_BUS_FLG_
LOG_PARM
F1T686P0
BUS_FLG_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_BUS_FLG_
REL
F1T682P0
BUS_FLG_ID,
BUS_FLG_REL_
TYPE_FLG,
SEQ_NUM
Global Partitioned
F1_BUS_FLG_
REL_OBJ
F1T683P0
BUS_FLG_ID,
BUS_FLG_REL_
OBJ_TYPE_FLG,
SEQ_NUM
Global Partitioned
Remote Message
This table describes the Remote Message maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_REMOTE_
MSG (Parent)
RANGE (ILM_DT,F1_REMOTE_MSG_ID)
RANGE(F1_REMOTE_MSG_ID)
F1_REMOTE_MSG.CRE_DTTM
F1T735P0
F1_REMOTE_MSG _ID
Global Partitioned
F1T735S1
CRE_DTTM
Global
F1T735S2
F1_MDT_ID
Global
F1T735S3
MAINT_OBJ_CD
Global
F1T735S4
PK_VALUE1
Global
F1T735S5
F1_DEVICE_MSG_ID
Global
F1T735S6
F1_MDT_ID,
F1_MSG_CLASS_FLG,
F1_DELIVERY_STATE_FLG
Global
CM_ILM_
F1T735S7
ILM_DT,
ILM_ARCH_SW,
F1_REMOTE_MSG_ID
Local Partitioned
F1_REMOTE_
MSG_CHA
F1T736P0
F1_REMOTE_MSG_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1T736S1
SRCH_CHAR_VAL
Global
F1_REMOTE_
MSG_LOG
F1T737P0
F1_REMOTE_MSG_ID, SEQNO
Global Partitioned
F1T737S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T737S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1_REMOTE_MSG_LOG_PARM
F1T738P0
F1_REMOTE_MSG_ID,
SEQNO, PARM_SEQ
Global Partitioned
Statistics Snapshot
This table describes the Statistics Snapshot maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_STATS_
SNPSHT(
Parent)
RANGE (ILM_DT,
SNAPSHOT_ID)
RANGE
(SNAPSHOT_ID)
F1_STATS_
SNPSHT.
CRE_DTTM
F1C706P0
SNAPSHOT_ID
Global Partitioned
F1C706S1
BUS_OBJ_CD,
BO_STATUS_CD,
SNAPSHOT_ID
Global
CM_ILM_
F1C706S2
ILM_DT,
ILM_ARCH_SW,
SNAPSHOT_ID
Local Partitioned
F1_STATS_
SNPSHT_CHAR
F1C707P0
SNAPSHOT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1C707S1
SRCH_CHAR_VAL
Global
F1_STATS_
SNPSHT_LOG
F1C708P0
SNAPSHOT_ID,
SEQNO
Global Partitioned
F1C708S1
CHAR_TYPE_CD, CHAR_VAL_FK1
Global
F1C708S2
Global
F1_STATS_SNPSHT_LOG_PARM
F1C709P0
SNAPSHOT_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_STATS_
SNPSHT_REL_
OBJ
F1C710P0
SNAPSHOT_ID,
STATS_SNPSHT_
REL_OBJ_TYPE_
FLG,
SEQ_NUM
Global Partitioned
Customer Relationship Request
This table describes the Customer Relationship Request maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CUST_REL_
REQ
RANGE(ILM_DT,CUST_REL_REQ_ID)
RANGE(CUST_REL_REQ_ID)
C1_CUST_REL_REQ.CRE_DTTM
C1T017P0
CUST_REL_REQ_
ID
Global Partitioned
C1T017S1
CUST_REL_REQ_
ID,
BUS_OBJ_CD,
BO_STATUS_CD
Global
CM_ILM_
C1T017S2
ILM_DT,
ILM_ARCH_SW,
CUST_REL_REQ_
ID
Local Partitioned
C1_CUST_REL_
REQ_CHAR
C1T014P0
CUST_REL_REQ_
ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
C1T014S1
SRCH_CHAR_VAL
Global
C1_CUST_REL_
REQ_LOG
C1T015P0
CUST_REL_REQ_
ID,
SEQNO
Global Partitioned
C1T015S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
C1T015S2
CHAR_TYPE_CD,
CHAR_VAL
Global
C1_CUST_REL_
REQ_LOG_PARM
C1T016P0
CUST_REL_REQ_
ID,
SEQNO,
PARM_SEQ
Global Partitioned
C1_CUST_REL_
REQ_REL_OBJ
C1T018P0
CUST_REL_REQ_
ID,
CRR_REL_OBJ_TY_FLG,
SEQ_NUM
Global Partitioned
Customer Contact
This table describes the Customer Contact maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_CC
RANGE(ILM_DT,CC_ID)
RANGE(CC_ID)
CI_CC. CC_DTTM, CI_CC. LETTER_PRINT_DTTM
XT057P0
CC_ID
Global Partitioned
XT057S1
PER_ID
Global
XT057S2
BATCH_CD,
BATCH_NBR,
CC_ID,
PRINT_LETTER_
SW
Global
XT057S3
CC_TYPE_CD,
CC_CL_CD,
CC_ID
Global
XT057S4
ACCT_ID
Global
XT057S6
C1_CONTACT_ID
Global
CM_ILM_
XT057S7
ILM_DT,ILM_
ARCH_SW,CC_ID
Local Partitioned
CI_CC_CHAR
Partitioning
CHAR_TYPE_CD
Partitioned
RANGE(CC_ID)
C1T007S1
SRCH_CHAR_VAL
Global
CI_CC_LOG
XT281P0
CC_LOG_ID
Global Partitioned
RANGE(CC_LOG_ID)
XT281S1
CC_ID
Global
Collection Process
This table describes the Collection Process maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_COLL_PROC
RANGE(CRE_
DTTM,COLL_
PROC_ID)
RANGE (COLL_PROC_
ID)
N/A
XT073P0
COLL_PROC_ID
Global Partitioned
XT073S1
ACCT_ID
Global
COLL_STATUS_
FLG
CI_COLL_EVT
XT069P0
COLL_PROC_ID,
EVT_SEQ
Global Partitioned
XT069S0
TRIGGER_BP_SW,
COLL_PROC_ID,
EVT_SEQ,
COLL_EVT_TYP_
CD
Global
CI_COLL_EVT_CC
XT070P0
COLL_PROC_ID,
EVT_SEQ,
CC_ID
Global Partitioned
XT070S1
CC_ID
Global
CI_COLL_PROC_
SA
XT074P0
COLL_PROC_ID,
SA_ID
Global Partitioned
XT074S1
SA_ID
Global
Cut Process
This table describes the Cut Process maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_CUT_PROC
RANGE(CRE_DTTM,CUT_PROC_ID)
RANGE (CUT_PROC_ID)
N/A
XT324P0
CUT_PROC_ID
Global Partitioned
XT324S1
OD_PROC_ID,
OD_EVT_SEQ
Global
CI_CUT_EVT
XT322P0
CUT_PROC_ID,
EVT_SEQ
Global Partitioned
CI_CUT_EVT_
DEP
XT323P0
CUT_PROC_ID,
EVT_SEQ,
SEQ_NUM
Global Partitioned
Overdue Process
This table describes the Overdue Process maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_OD_PROC
RANGE(CRE_DTTM,OD_PROC_ID)
RANGE (OD_PROC_ID)
N/A
XT315P0
OD_PROC_ID
Global Partitioned
CI_OD_EVT
XT318P0
OD_PROC_ID,
EVT_SEQ
Global Partitioned
CI_OD_EVT_
DEP
XT319P0
OD_PROC_ID,
EVT_SEQ,
SEQ_NUM
Global Partitioned
CI_OD_PROC_LOG
XT320P0
OD_PROC_ID,
LOG_SEQ
Global Partitioned
XT320S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
CI_OD_PROC_LOGPARM
XT321P0
OD_PROC_ID,
LOG_SEQ,
PARM_SEQ
Global Partitioned
CI_OD_PROC_OBJ
XT317P0
OD_PROC_ID,
SEQ_NUM
Global Partitioned
Severance Event
This table describes the Severance Event maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_SEV_PROC
RANGE(CRE_DTTM,SEV_PROC_ID)
RANGE (SEV_PROC_ID)
N/A
XT118P0
SEV_PROC_ID
Global Partitioned
XT118S1
SA_ID,
SEV_PROC_ID
Global
XT118S2
COLL_PROC_ID, EVT_SEQ
Global
CI_SEV_EVT
XT214P0
SEV_PROC_ID,
EVT_SEQ
Global Partitioned
CI_SEV_EVT_DEP
XT216P0
SEV_PROC_ID,
EVT_SEQ,
SEQ_NUM
Global Partitioned
CI_SEV_EVT_FA
XT217P0
SEV_PROC_ID,
EVT_SEQ,
FA_ID
Global Partitioned
XT217S1
FA_ID
Global
CI_SEV_EVT_CC
XT215P0
SEV_PROC_ID,
EVT_SEQ,
CC_ID
Global Partitioned
XT215S1
CC_ID
Global
WO Process
This table describes the WO Process maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_WO_PROC
RANGE(CRE_DTTM,WO_PROC_ID)
RANGE (WO_PROC_ID)
N/A
XT061P0
WO_PROC_ID
Global Partitioned
XT061S1
ACCT_ID,
WO_STATUS_FLG
Global
CI_WO_EVT
XT059P0
WO_PROC_ID,
EVT_SEQ
Global Partitioned
CI_WO_EVT_CC
XT060P0
WO_PROC_ID,
EVT_SEQ,
CC_ID
Global Partitioned
XT060S1
CC_ID
Global
CI_WO_PROC_SA
XT062P0
WO_PROC_ID,
SA_ID
Global Partitioned
XT062S1
SA_ID,
WO_SA_STAT_
FLG
Global
General Audit
This table describes the General Audit maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_GNRL_
AUDIT
RANGE(ILM_DT, AUDIT_ID)
RANGE (AUDIT_ID)
F1_GNRL_AUDIT.CRE_DTTM
F1T901P0
AUDIT_ID
Global Partitioned
F1T901S1
USER_ID
Global
F1T901S1
AUDIT_ID,
USER_ID,
CRE_DTTM
Global
CM_ILM_
F1T901S3
ILM_DT,
ILM_ARCH_SW,
AUDIT_ID
Local Partitioned
F1_GNRL_
AUDIT_CHAR
F1C504P0
AUDIT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1C504S1
SRCH_CHAR_VAL
Global
F1_GNRL_
AUDIT_VAL
F1T902P0
AUDIT_ID,
FLD_NAME
Global Partitioned
F1T902S1
AUDIT_ID,
FLD_NAME,
FLD_VAL
Global
Meter Read
This table describes the Meter Read maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_MR
RANGE(ILM_DT,MR_ID)
RANGE(MR_ID)
CI_MR.READ_DTTM,
XT132P0
MR_ID
Global Partitioned
XT132S1
MTR_CONFIG_ID, USE_ON_BILL_SW, READ_DTTM, MR_ID
Global
CM_ILM_
XT132L0
ILM_DT,ILM_ARCH_SW,MR_ID
Local Partitioned
CI_MR_CHAR
XT410P0
MR_ID, CHAR_TYPE_CD, SEQ_NUM
Global Partitioned
RANGE(MR_ID)
XTT410S1
SRCH_CHAR_VAL
Global
CI_MR_REM
XT135P0
MR_ID, READER_REM_CD
Global Partitioned
RANGE(MR_ID)
CI_MR_REM_EXCP
XT024P0
Global
Partitioned
RANGE(MR_ID)
CI_REG_READ
XT186P0
REG_READ_ID
Global Partitioned
RANGE(REG_READ_ID)
XT186S1
MR_ID
Global
XT186S2
REVIEW_HILO_SW, TRENDED_SW, REG_READ_ID
Global
XT186S3
REG_ID
Global
Payment Arrangement Process
This table describes the Payment Arrangement Process maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_PA_RQST (Parent)
RANGE (ILM_DT,PA_RQST_ID)
C1_PA_RQST.CRE_DTTM
C1T020P0
PA_RQST_ID
Global Partitioned
RANGE (PA_RQST_ID)
C1T020S1
PA_RQST_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_
C1T020S2
ILM_DT,ILM_ARCH_SW,PA_RQST_ID
Local Partitioned
C1_PA_RQST_
CHAR
C1T024P0
PA_RQST_ID, CHAR_TYPE_CD, SEQ_NUM
Global Partitioned
C1T024S1
SRCH_CHAR_VAL
Global
C1_PA_RQST_ELIG_RSLT
C1T022P0
PA_RQST_ID, PA_RQST_ELIG_
CRIT_SEQ
Global Partitioned
C1_PA_RQST_
LOG
C1T025P0
PA_RQST_ID, SEQNO
Global Partitioned
C1T025S1
Global
C1T025S2
Global
C1_PA_RQST_
LOG_PARM
C1T026P0
PA_RQST_ID, SEQNO, PARM_SEQ
Global Partitioned
C1_PA_RQST_REL_OBJ
C1T023P0
PA_RQST_ID, PA_RQST_REL_
OBJ_TYPE_FLG, SEQ_NUM
Global Partitioned
Customer Service Request
This table describes the Customer Service Request maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ (Parent)
RANGE (ILM_DT,CS_
REQ_ID)
C1_CS_REQ.CRE_DTTM
C1T043P0
CS_REQ_ID
Global Partitioned
RANGE (CS_REQ_ID)
C1T043S1
CS_REQ_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_
C1T043S2
ILM_DT,ILM_ARCH_SW,CS_REQ_ID
Local Partitioned
C1T044P0
CS_REQ_ID, CHAR_TYPE_CD, SEQ_NUM
Global Partitioned
C1T044S1
SRCH_CHAR_VAL
Global
C1T046P0
CS_REQ_ID, SEQNO
Global Partitioned
C1T046S1
Global
C1T046S2
Global
C1_CS_REQ_
LOG_PARM
C1T047P0
CS_REQ_ID, SEQNO, PARM_SEQ
Global Partitioned
C1_CS_REQ_
REL_OBJ
C1T045P0
CS_REQ_ID, CS_REQ_REL_OBJ_TYPE_FLG, SEQ_NUM
Global Partitioned
Customer Service Request Account
This table describes the Customer Service Request Account maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ_
ACCT (Parent)
RANGE (ILM_DT,CS_
REQ_ACCT_ID)
C1_CS_REQ_ACCT.CRE_DTTM
C1T079P0
CS_REQ_ACCT_ID
Global Partitioned
RANGE (CS_REQ_ACCT_ID)
C1T079S1
CS_REQ_ACCT_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_
C1T079S2
ILM_DT,ILM_ARCH_SW,CS_REQ_ACCT_ID
Local Partitioned
C1_CS_REQ_
ACCT_ALERT
C1T081P0
CS_REQ_ACCT_ID, CS_REQ_SEQ_
NUM
Global Partitioned
C1_CS_REQ_
ACCT_APAY
C1T082P0
NUM
Global Partitioned
C1_CS_REQ_
ACCT_CHAR
C1T083P0
NUM
Global Partitioned
C1T083S1
SRCH_CHAR_VAL
Global
C1_CS_REQ_
ACCT_LOG
C1T090P0
CS_REQ_ACCT_ID, SEQNO
Global Partitioned
C1T090S1
Global
C1T090S2
Global
C1_CS_REQ_ACCT_LOG_PARM
C1T091P0
CS_REQ_ACCT_ID, SEQNO, PARM_SEQ
Global Partitioned
C1_CS_REQ_ACCT_MSG
C1T084P0
NUM
Global Partitioned
C1_CS_REQ_ACCT_MSG_PARM
C1T085P0
NUM, CS_REQ_MSG_
PARM_SEQ
Global Partitioned
C1_CS_REQ_ACCT_NCD
C1T089P0
NUM
Global Partitioned
C1_CS_REQ_ACCT_PER
C1T086P0
CS_REQ_ACCT_
PER_ID
Global Partitioned
C1_CS_REQ_ACCT_PER_ADDR
C1T088P0
CS_REQ_ACCT_
PER_ID
Global Partitioned
Customer Service Request Consumer Contract
This table describes the Customer Service Request Consumer Contract maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ_
CONT (Parent)
RANGE (ILM_DT,CS_
REQ_CONT_ID)
C1_CS_REQ_CONT.CRE_DTTM
C1T055P0
CS_REQ_CONT_
ID
Global Partitioned
RANGE (CS_REQ_CONT_ID)
C1T055S1
CS_REQ_CONT_
CD
Global
CM_ILM_
C1T055S2
ILM_DT,ILM_
ARCH_SW,
CS_REQ_CONT_
ID
Local Partitioned
C1_CS_REQ_
CONT_CHAR
C1T058P0
CS_REQ_CONT_
ID, CS_REQ_SEQ_
NUM
Global Partitioned
C1T058S1
SRCH_CHAR_VAL
Global
C1_CS_REQ_
CONT_ID
C1T057P0
CS_REQ_CONT_
ID, CS_REQ_SEQ_
NUM
Global
C1_CS_REQ_
LOG
C1T062P0
CS_REQ_CONT_
ID, SEQNO
Global Partitioned
C1T062S1
Global
C1T062S2
Global
C1_CS_REQ_CONT_LOG_PARM
C1T064P0
CS_REQ_CONT_
ID, SEQNO, PARM_SEQ
Global Partitioned
C1_CS_REQ_CONT_MS
C1T059P0
CS_REQ_CONT_
ID, CS_REQ_SEQ_
NUM
Global Partitioned
C1T061P0
CS_REQ_CONT_
ID, CS_REQ_SEQ_
NUM, SEQ_NUM
Global Partitioned
Customer Service Request Contract Product
This table describes the Customer Service Request Contract Product maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ_
CONT_PROD (Parent)
RANGE (ILM_DT,CS_
REQ_CONT_PROD_ID)
C1_CS_REQ_CONT_PROD.CRE_DTTM
C1T065P0
CS_REQ_CONT_PROD_ID
Global Partitioned
RANGE (CS_REQ_CONT_PROD_ID)
C1T065S1
CS_REQ_CONT_
PROD_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_
C1T065S2
ILM_DT,ILM_ARCH_SW,CS_REQ_CONT_PROD_ID
Local Partitioned
C1T067P0
CS_REQ_CONT_
PROD_ID, CS_REQ_SEQ_
NUM
Global Partitioned
C1T067S1
SRCH_CHAR_VAL
Global
C1_CS_REQ_CONT_PROD_LOG
C1T068P0
CS_REQ_CONT_PROD_ID, SEQNO
Global Partitioned
C1T068S1
Global
C1T068S2
Global
C1T069P0
CS_REQ_CONT_PROD_ID, SEQNO, PARM_SEQ
Global Partitioned
Customer Service Request Person
This table describes the Customer Service Request Person maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ_
PER (Parent)
RANGE (ILM_DT,CS_REQ_PER_ID)
RANGE (CS_REQ_PER_
ID)
C1_CS_REQ_
PER.CRE_DTTM
C1T070P0
CS_REQ_PER_ID
Global Partitioned
C1T070S1
CS_REQ_PER_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_
C1T070S2
PER_ID
Local Partitioned
C1_CS_REQ_PER_ADDR_SEAS
C1T074P0
CS_REQ_PER_ID, CS_REQ_SEQ_
NUM
Global Partitioned
C1_CS_REQ_PER_CHAR
C1T075P0
NUM
Global Partitioned
C1T075S1
SRCH_CHAR_VAL
Global
C1_CS_REQ_PER_CONTDET
C1T073S1
NUM
Global
C1_CS_REQ_PER_ID
C1T072S1
NUM
Global
C1_CS_REQ_PER_LOG
C1T077P0
CS_REQ_PER_ID, SEQNO
Global Partitioned
C1T077S1
Global
C1T077S2
Global
C1_CS_REQ_
PER_LOG_
PARM
C1T078P0
CS_REQ_PER_ID, SEQNO, PARM_SEQ
Global Partitioned
C1_CS_REQ_
PER_NAME
C1T071P0
NUM
Global Partitioned
C1_CS_REQ_
PER_PER
C1T076P0
NUM
Global Partitioned
Customer Service Request Service Location
This table describes the Customer Service Request Service Location maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ_
SVC_LOC (Parent)
RANGE (ILM_DT,CS_REQ_SVC_LOC_ID)
C1_CS_REQ_SVC_LOC.CRE_
DTTM
C1T049P0
CS_REQ_SVC_LOC_ID
Global
Partitioned
RANGE (CS_REQ_SVC_LOC_ID)
C1T049S1
CS_REQ_SVC_LOC_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_
C1T049S2
ILM_DT,ILM_ARCH_SW,CS_REQ_SVC_LOC_ID
Local Partitioned
C1_CS_REQ_SVC_LOC_CHAR
C1T051P0
CS_REQ_SVC_LOC_ID, CHAR_TYPE_CD, SEQ_NUM
Global Partitioned
C1T051S1
SRCH_CHAR_VAL
Global
C1_CS_REQ_SVC_LOC_CONT_PROD
C1T052P0
CS_REQ_SVC_LOC_ID, CS_REQ_SEQ_NUM
Global
C1_CS_REQ_SVC_LOC_LOG
C1T053P0
CS_REQ_SVC_LOC_ID, SEQNO
Global Partitioned
C1T053S1
Global
C1T053S2
Global
C1_CS_REQ_SVC_LOC_LOG_PARM
C1T054P0
CS_REQ_SVC_LOC_ID, SEQNO, PARM_SEQ
Global Partitioned
Customer Service Request Premise
This table describes the Customer Service Request Premise maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ_PREM (Parent)
RANGE (ILM_DT,CS_REQ_PREM_ID)
C1_CS_REQ_PREM.CRE_DTTM
C1T092P0
CS_REQ_PREM_ID
Global Partitioned
RANGE (CS_REQ_PREM_ID)
CM_ILM_
C1T092S1
ILM_DT, ILM_ARCH_SW, CS_REQ_PREM_ID
Local Partitioned
C1_CS_REQ_PREM_ALT_ADDR
C1T095P0
CS_REQ_PREM_ID, CS_REQ_SEQ_
NUM
Global
C1_CS_REQ_PREM_CHAR
C1T093P0
NUM
Global Partitioned
C1T093S1
SRCH_CHAR_VAL
Global
C1_CS_REQ_PREM_GEO
C1T094P0
NUM
Global
C1_CS_REQ_PREM_LOG
C1T096P0
CS_REQ_PREM_ID, SEQNO
Global Partitioned
C1T096S1
Global
C1T096S2
Global
C1_CS_REQ_PREM_LOG_PARM
C1T097P0
CS_REQ_PREM_ID, SEQNO, PARM_SEQ
Global Partitioned
Market Charge
This table describes the Market Charge maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_MKTMSG_CHG (Parent)
RANGE (ILM_DT,MKTMSG_CHG_ID)
C1_MKTMSG_CHG.MKT_CHG_DT
C1T135P0
MKTMSG_CHG_ID
Global Partitioned
RANGE (MKTMSG_CHG_ID)
C1T135S1
MKTMSG_CHG_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_C1T135S2
ILM_DT,ILM_ARCH_SW,MKTMSG_
CHG_ID
C1_MKTMSG_CHG_DTL
C1T137P0
MKTMSG_CHG_ID, MKT_SEQNO
Global Partitioned
C1_MKTMSG_CHG_LOG
C1T139P0
MKTMSG_CHG_ID, SEQNO
Global Partitioned
C1T139S1
Global
C1T139S2
Global
C1_MKTMSG_CHG_LOG_PARM
C1T140P0
MKTMSG_CHG_ID, SEQNO, PARM_SEQ
Global Partitioned
C1_MKTMSG_CHG_REL_OBJ
C1T138P0
MKTMSG_CHG_ID, MKT_REL_OBJ_
TYPE_FLG, SEQNO
Global Partitioned
Market Payment
This table describes the Market Payment maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_MKTMSG_PAY (Parent)
RANGE (ILM_DT,MKTMSG_PAY_ID)
C1_MKTMSG_
PAY.MKT_PAY_
DT
C1T129P0
MKTMSG_PAY_ID
Global Partitioned
RANGE (MKTMSG_PAY_ID)
C1T129S1
MKTMSG_PAY_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_
C1T129S2
ILM_DT,ILM_ARCH_SW,MKTMSG_PAY_ID
Local Partitioned
C1_MKTMSG_PAY_DTL
C1T131P0
MKTMSG_PAY_ID, MKT_SEQNO
Global Partitioned
C1_MKTMSG_PAY_LOG
C1T133P0
MKTMSG_PAY_ID, SEQNO
Global Partitioned
C1T133S1
Global
C1T133S2
Global
C1_MKTMSG_PAY_LOG_PARM
C1T134P0
MKTMSG_PAY_ID, SEQNO, PARM_SEQ
Global Partitioned
C1_MKTMSG_PAY_REL_OBJ
C1T132P0
MKTMSG_PAY_ID, MKT_REL_OBJ_TYPE_FLG, SEQNO
Global Partitioned
Market Usage
This table describes the Market Usage maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_MKTMSG_USG (Parent)
RANGE (ILM_DT,MKTMSG_USG_ID)
C1_MKTMSG_
USG.MKT_USG_
DT
C1T123P0
MKTMSG_USG_ID
Global Partitioned
C1T123S1
MKTMSG_USG_ID, BUS_OBJ_CD, BO_STATUS_CD
Global
CM_ILM_C1T123S2
ILM_DT,ILM_ARCH_SW,MKTMSG_USG_ID
Local Partitioned
C1_MKTMSG_
USG_DTL
C1T125P0
MKTMSG_USG_ID, MKT_SEQNO
Global Partitioned
C1_MKTMSG_
USG_LOG
C1T127P0
MKTMSG_USG_ID, SEQNO
Global Partitioned
C1T127S1
Global
C1T127S2
Global
C1_MKTMSG_
USG_LOG_
PARM
C1T128P0
Global Partitioned
C1_MKTMSG_
USG_REL_OBJ
C1T126P0
Global Partitioned
Customer Service Request SA
This table describes the Customer Service Request SA maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_CS_REQ_SA
(Parent)
RANGE (ILM_DT,
CS_REQ_SA_ID)
C1_CS_REQ_SA.CRE_DTTM
C1T141P0
CS_REQ_SA_ID
Global Partitioned
RANGE(CS_REQ_SA_ID)
C1T141S1
CS_REQ_SA_ID,
BUS_OBJ_CD,
BO_STATUS_CD
Global
CM_ILM_
C1T141S2
ILM_DT,ILM_ARCH_SW,CS_REQ_SA_ID
Local Partitioned
C1_CS_REQ_SA_CHAR
C1T143P0
CS_REQ_SA_ID, CS_REQ_SEQ_
NUM
Global Partitioned
C1T143S1
SRCH_CHAR_VAL
Global
C1_CS_REQ_SA_LOG
C1T156P0
CS_REQ_SA_ID, SEQNO
Global Partitioned
C1T156S1
Global
C1T156S2
CHAR_TYPE_CD,
CHAR_VAL
Global
C1_CS_REQ_SA_LOG_PARM
C1T157P0
CS_REQ_SA_ID,
SEQNO,
PARM_SEQ
Global
Partitioned
C1_CS_REQ
SA_CONTERM
C1T151P0
CS_REQ_SA_ID,
CS_REQ_SEQ_
NUM
Global
Partitioned
C1_CS_REQ_SA_
CONT_QTY
C1T149P0
CS_REQ_SA_ID,
CS_REQ_SEQ_
NUM
Global
Partitioned
C1_CS_REQ_SA_
COP
Reference
Partitioning
C1T153P0
CS_REQ_SA_ID,CS_REQ_SEQ_
NUM
Global
Partitioned
C1_CS_REQ_SA_
COP_OVRD
C1T154P0
NUM,SEQNUM
Global
Partitioned
C1_CS_REQ_SA_
MSG
C1T155P0
CS_REQ_SA_ID,CS_REQ_SEQ_NUM
Global
Partitioned
C1_CS_REQ_SA_
RCHG
C1T150P0
CS_REQ_SA_ID,
CS_REQ_SEQ_
NUM
Global
Partitioned
C1_CS_REQ_SA_RS
C1T148P0
CS_REQ_SA_ID,
CS_REQ_SEQ_
NUM
Global
Partitioned
C1_CS_REQ_SA_TOU_CONT_
VAL
C1T152P0
CS_REQ_SA_ID, CS_REQ_SEQ_NUM,SEQ_NUM
Global
Partitioned
C1_CS_REQ_SA_SP
C1T144P0
CS_REQ_SA_SP_ID, CS_REQ_SEQ_
NUM
Global
Partitioned
RANGE
(CS_REQ_SA_SP_ID)
C1_CS_REQ_SA_
SP_CHAR
Reference
Partitioning
C1T147P0
CS_REQ_SA_SP_ID,CS_REQ_SEQ_
NUM
Global
Partitioned
C1_CS_REQ_SA_
SP_FA
Reference
Partitioning
C1T146P0
NUM
Global
Partitioned
SA Arrears Snapshot
This table describes the SA Arrears Snapshot maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_BI_SA_
SNAPSHOT
(Parent)
RANGE
(ILM_DT,SA_ID)
C1_BI_SA_SNAP
SHOT.C1_SNAPS
HOT_DTTM
C1M020P0
SA_ID,C1_
SNAPSHOT_DTTM, C1_SNAPSHOT_
TYPE_FLG
Global
Partitioned
RANGE (SA_ID)
C1M020S1
SA_ID
Global
C1M020S2
ACCT_ID
Global
C1M020S3
PER_ID
Global
C1M020S4
CURRENCY_CD
Global
CM_ILM_
C1M020S5
ILM_DT,ILM_
ARCH_SW, SA_ID
Local Partitioned
Notification Preference
This table describes the Notification Preference maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
C1_NTF_
PREF (Parent)
RANGE (ILM_DT,NTF_PREF_ID)
C1_NTF_PREF.STATUS_UPD_DTTM
C1T002P0
NTF_PREF_ID
Global Partitioned
RANGE (NTF_PREF_
ID)
C1T002S1
ACCT_ID
Global
C1T002S2
NTF_PREF_ID,BO_STATUS_CD,STATUS_UPD_DTTM
Global
C1T002S3
C1_CONTACT_ID
Global
CM_ILM_C1T002S4
ILM_DT,ILM_ARCH_SW,NTF_PREF_ID
Local
C1_NTF_
PREF_CHAR
C1T003P0
NTF_PREF_ID, CHAR_TYPE_
CD, SEQ_NUM
Global Partitioned
C1T003S1
SRCH_CHAR_
VAL
Global
C1_NTF_
PREF_LOG
C1T004P0
NTF_PREF_ID, SEQNO
Global Partitioned
C1T004S1
FK1
Global
C1T004S2
CHAR_TYPE_
CD, CHAR_VAL
Global
C1_NTF_PREF_LOG_PARM
C1T005P0
NTF_PREF_ID, SEQNO, PARM_SEQ
Global Partitioned
C1_NTF_
PREF_ID
C1T006P0
NTF_PREF_ID,NTF_PREF_ID_TYPE_FLG
Global Partitioned
Inbound Market Message
This table describes the Inbound Market Message maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_MKTMSG_IN(Parent)
RANGE(ILM_DT,MKTMSG_ID)
F1T759P0
MKTMSG_ID
Global Partitioned
Range(MKTMSG_ID)
F1_MKTMSG_IN.CRE_DTTM
F1T759S1
BO_STATUS_CD,
BUS_OBJ_CD,
MKTMSG_ID
Global
CM_ILM_F1T759L0
ILM_DT,
ILM_ARCH_SW, MKTMSG_ID
Local Partitioned
F1_MKTMSG_IN_CHAR
F1T760P0
MKTMSG_ID,
CHAR_TYPE_CD,SEQ_NUM
Global Partitioned
F1T760S1
SRCH_CHAR_VAL
Global
F1_MKTMSG_IN_DATA
F1T761P0
MKTMSG_ID,
MKT_DATA_TYPE_FLG
Global Partitioned
F1T762P0
MKTMSG_ID,
MKT_REF_TYPE_FLG,
SEQNO
Global Partitioned
F1_MKTMSG_IN_ID
F1T763P0
MKTMSG_ID,
MKT_ID_TYPE_FLG
Global Partitioned
F1_MKTMSG_IN_LOG
F1T765P0
MKTMSG_ID,
SEQNO
Global Partitioned
F1T765S1
CHAR_TYPE_
CD,CHAR_VAL_FK1
Global
F1T765S2
CHAR_TYPE_
CD, CHAR_VAL
Global
F1_MKTMSG_IN_LOG_PARM
F1T766P0
MKTMSG_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_MKTMSG_IN_REL_OBJ
F1T767P0
MKTMSG_ID,
SEQNO
Global Partitioned
Outbound Market Message
This table describes the Outbound Market Message maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_MKTMSG_OUT(Parent)
F1T782P0
MKTMSG_ID
Global Partitioned
Range(MKTMSG_ID)
F1_MKTMSG_OUT.CRE_DTTM
F1T782S1
BO_STATUS_CD,
BUS_OBJ_CD,
MKTMSG_ID
Global
CM_ILM_F1T782L0
ILM_DT,
Local Partitioned
F1_MKTMSG_OUT_CHAR
F1T783P0
MKTMSG_ID,
CHAR_TYPE_
CD,
SEQ_NUM
Global Partitioned
F1T783S1
SRCH_CHAR_VAL
Global
F1_MKTMSG_OUT_DATA
F1T784P0
MKTMSG_ID,
MKT_DATA_TYPE_FLG
Global Partitioned
F1_MKTMSG_OUT_EXT_
REF
F1T785P0
MKTMSG_ID,
MKT_REF_TYPE_FLG,
SEQNO
Global Partitioned
F1_MKTMSG_OUT_ID
F1T786P0
MKTMSG_ID,
MKT_ID_TYPE_FLG
Global Partitioned
F1_MKTMSG_OUT_LOG
F1T788P0
MKTMSG_ID,
SEQNO
Global Partitioned
F1T788S1
FK1
Global
F1T788S2
Global
F1_MKTMSG_OUT_LOG_PARM
F1T789P0
MKTMSG_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_MKTMSG_OUT_REL_
OBJ
F1T790P0
MKTMSG_ID,
SEQNO
Global Partitioned
Market Process
This table describes the Market Process maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_MKTPROC
(Parent)
Range(ILM,MKTPROC_ID)
F1T768P0
MKTPROC_ID
Global Partitioned
Range (MKTPROC_
ID)
F1_MKTPROC.CRE_
DTTM
F1T768S1
BO_STATUS_
CD,
BUS_OBJ_CD,
MKTPROC_ID
Global
CM_ILM_F1T768L0
ILM_DT,
ILM_ARCH_
SW,
MKTPROC_ID
Local Partitioned
F1_MKTPROC_CHAR
F1T769P0
MKTPROC_ID,
CHAR_TYPE_
CD,
SEQ_NUM
Global Partitioned
F1T769S1
SRCH_CHAR_VAL
Global
F1_MKTPROC_ID
F1T770P0
MKTPROC_ID,
MKT_ID_TYPE_FLG
Global Partitioned
F1_MKTPROC_LOG
F1T772P0
MKTPROC_ID,
SEQNO
Global Partitioned
F1_MKTPROC_LOG_PARM
F1T773P0
MKTPROC_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_MKTPROC_REL_OBJ
F1T775P0
MKTPROC_ID,
SEQNO
Global Partitioned
F1_MKTPROC_REL_PROC
F1T774P0
MKTPROC_ID,
MKTPROC_REL_ID,
MKTPROC_REL_TYPE_FLG
Global Partitioned
Market Process Event
This table describes the Market Process Event maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_MKTPROC_EVT(Parent)
Range(ILM_DT,MKTPROC_EVT_ID)
F1T776P0
MKTPROC_EVT_ID
Global Partitioned
Range(MKTPROC_EVT_ID)
F1_MKTPROC_EVT.CRE_DTTM
F1T776S1
MKTPROC_ID
Global
F1T776S2
MKT_REG_
NBR, BUS_OBJ_CD,
BO_STATUS_
CD
Global
F1T776S3
BO_STATUS_CD,
BUS_OBJ_CD,
MKTPROC_EVT_ID
Global
CM_ILM_F1T776L0
ILM_DT,
ILM_ARCH_SW, MKTPROC_
EVT_ID
Local Partitioned
F1_MKTPROC_EVT_CHAR
F1T777P0
MKTPROC_EVT_ID,
Global Partitioned
F1T777S1
SRCH_CHAR_
VAL
Global
F1_MKTPROC_EVT_LOG
F1T779P0
MKTPROC_EVT_ID, SEQNO
Global Partitioned
F1T779S1
FK1
Global
F1T779S2
Global
F1_MKTPROC_EVT_LOG_
PARM
F1T780P0
MKTPROC_EVT_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_MKTPROC_EVT_REL_
OBJ
F1T781P0
MKTPROC_EVT_ID,
SEQNO
Global Partitioned
Mobile Remote Message
This table describes the Mobile Remote Message maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_REMOTE_MSG (Parent)
Range(ILM_DT,F1_REMOTE_MSG_ID)
F1T735P0
F1_REMOTE_MSG_ID
Global Partitioned
Range(F1_REMOTE_MSG_ID)
F1T735S1
CRE_DTTM
Global
F1T735S2
F1_MDT_ID
Global
F1T735S3
MAINT_OBJ_
CD
Global
F1T735S4
PK_VALUE1
Global
F1T735S5
F1_DEVICE_
MSG_ID
Global
F1T735S6
F1_MDT_ID,
F1_MSG_CLASS_FLG,
Global
F1T735S7
BO_STATUS_
CD,
BUS_OBJ_CD,
F1_REMOTE_MSG_ID
Global
CM_ILM_F1T735L0
ILM_DT,
ILM_ARCH_SW, F1_REMOTE_
MSG_ID
Local Partitioned
F1_REMOTE_MSG_CHAR
F1T736P0
F1_REMOTE_MSG_ID,
CHAR_TYPE_
CD, SEQ_NUM
Global Partitioned
F1T736S1
SRCH_CHAR_
VAL
Global
F1_REMOTE_MSG_LOG
F1T737P0
Global Partitioned
F1T737S1
FK1
Global
F1T737S2
Global
F1T738P0
F1_REMOTE_MSG_ID,
SEQNO,
PARM_SEQ
Global Partitioned
