Parameter | ALLOW_SELFSIGNED_SSL |
Description | Specifies if self signed SSL is allowed |
Ordinality | Mandatory |
Valid Values | [true|false] |
Tier | Web Application Server, Business Application Server |
Parameter | ANT_ADDITIONAL_OPT |
Description | Implementation specific options for WAR and EAR builds used by starttpw.sh - Start Threadpoolworker. |
Ordinality | Optional |
Valid Values | Valid ANT options |
Tier | Web Application Server, Business Application Server, Inbound Web Services, Background Processing. |
Parameter | ANT_HOME |
Description | Generated location of ANT used by starttpw.sh - Start Threadpoolworker. This value is autogenerated and should not be altered. |
Valid Values | Valid location of ANT |
Parameter | ANT_OPT_MAX |
Description | Maximum memory in MB allocated to ANT builds. Unless otherwise instructed by Oracle Support this value should not be altered. |
Valid Values | Default: 800 |
Parameter | ANT_OPT_MIN |
Description | Minimum memory in MB allocated to ANT builds. Unless otherwise instructed by Oracle Support this value should not be altered. |
Valid Values | Default: 200 |
Parameter | appViewer |
Description | Name of AppViewer WAR file |
Valid Values | This value is automatically generated |
Parameter | BATCHDAEMON |
Description | Whether the Online Batch Deamon is enabled or not. |
Tier | Business Application Server, Background Processing. |
Parameter | BATCHEDIT_ENABLED |
Description | Whether the Batch Edit facility is enabled or not. |
Tier | Background Processing. |
Parameter | BATCHENABLED |
Description | Whether the Online Batch Server is enabled or not. |
Parameter | BATCHTHREADS |
Description | Number of Threads in DEFAULT online threadpool. |
Valid Values | Default: 5 |
Tier | Business Application Server |
Parameter | BATCH_DBPASS |
Description | Encrypted password for database user used for batch. |
Valid Values | Encrpyted password |
Tier | Background Processing, Database. |
Parameter | BATCH_DBUSER |
Description | Database user used for batch. |
Valid Values | Valid database user |
Parameter | BATCH_MEMORY_ADDITIONAL_OPT |
Description | Additional JVM Options for Threadpools |
Valid Values | Valid Threadpool parameters. Example: BATCH_MEMORY_ADDITIONAL_OPT=-Xdebug -Xnoagent -Xrunjdwp:transport=dt_socket,address=7757, server=y,suspend=n -Djava.compiler=NONE |
Tier | Background Processing |
Parameter | BATCH_MEMORY_OPT_MAX |
Description | Maximum JVM Memory for each Threadpool instance |
Valid Values | Memory specification (in MB). Default: 1024 |
Parameter | BATCH_MEMORY_OPT_MIN |
Description | Minimum JVM Memory for each Threadpool instance |
Valid Values | Memory specification (in MB). Default: 512 |
Parameter | BATCH_MODE |
Description | Batch Execution Mode for Threadpools |
Valid Values | [THIN |CLUSTERED] |
Parameter | BATCH_ONLINE_LOG_DIR |
Description | Location of Online Batch Submission logs |
Valid Values | Valid directory |
Parameter | BATCH_RMI_PORT |
Description | Port number used for communication to Threadpools. This is used for JMX monitoring. |
Valid Values | Valid Port Number |
Parameter | BSN_APP |
Description | Deployed Business Application Server Name |
Valid Values | Default: SPLService |
Parameter | BSN_JMX_RMI_PORT_PERFORMANCE |
Description | JMX Port for Business Application Server monitoring |
Valid Values | Valid open port for JMX |
Parameter | BSN_JMX_SYSPASS |
Description | Default encrypted password for JMX monitoring of Business Application Server Name for BSN_JMX_SYSUSER. This is required if BSN_JMX_RMI_PORT_PERFORMANCE is set. |
Valid Values | Encrypted Password |
Parameter | BSN_JMX_SYSUSER |
Description | Default user for JMX monitoring of Business Application Server Name. This is required if BSN_JMX_RMI_PORT_PERFORMANCE is set. |
Valid Values | Administration User |
Parameter | BSN_WLHOST |
Description | Oracle WebLogic host name for Business Application Server. For native and/or clustered installations this setting may be set to localhost. |
Valid Values | Default: Current Host Name |
Parameter | CALC_WLS_COMMON_JAR_DIR |
Description | The full path to the jersey Jars in weblogic install directory. |
Valid Values | Full path |
Tier | Web Application Server, Business Application Server, Background Processing. |
Parameter | CALC_WLS_SERVER_JAR_DIR |
Description | The full path to the weblogic server lib Jars in weblogic install directory. |
Parameter | CHAR_BASED_DB |
Description | Specifies if the DB is char based. |
Valid Values | [true | false] |
Parameter | CLOUD_CUSTOM_WHITE_LIST_PATH |
Description | The full path to a custom allow list for aliases for URLs within the product. This allow list is added to the base product allowlist which is provided in CLOUD_WHITE_LIST_PATH variable. This is primarily for cloud implementations to define URL aliases. See Support for host allow listing. |
Valid Values | Full path (including filename to allow list file) |
Parameter | CLOUD_LOCATION_F1_BASE_IWS_URI |
Description | The base WSDL URI is different than the application server URI and must be configured for cloud implementations. Need not be configured for on-premise implementations. |
Tier | Web Application Server, Business Application Server. |
Parameter | CLOUD_LOCATION_F1_BASE_REST_URL |
Description | URI for variable F1_BASE_REST_URL. This is for implementations to define the base URI for REST. This is primarily for cloud implementations. |
Parameter | CLOUD_LOCATION_F1_BASE_WEB_URI |
Description | The environment URL used to launch the application server from an external link must be configured for cloud implementations. Need not be configured for on-premise implementations. |
Parameter | CLOUD_LOCATION_F1_MIGR_ASSISTANT_FILES |
Description | The full path to the location of the CMA files for content migration. This is primarily for cloud implementations to define the configuration file location for the CMA process. |
Parameter | CLOUD_LOCATION_F1_OAUTH2_URI |
Description | The URI for implementing OAUTH2. This is primarily for cloud implementations to implement OAUTH2. |
Valid Values | Full URI |
Parameter | CLOUD_RESTRICTIONS_URL_ENABLE |
Description | Whether the allow lists for URL's are enabled. This is primarily for cloud implementations. |
Parameter | CLOUD_SUBSTITUTION_VARIABLE_LIST_FILE_LOCATION |
Description | Points to the file containing the predefined URI substitution variable list. This is primarily for cloud implementations. |
Ordinality | Optional [ Mandatory only for Cloud implementations] |
Valid Values | Full path (including the filename for substitution list) |
Parameter | CLOUD_WHITE_LIST_PATH |
Description | The full path to a base allow list for aliases for URLs within the product. This allow list is added with the custom product allow list which is provided in CLOUD_CUSTOM_WHITE_LIST_PATH variable. This is primarily for cloud implementations to define URL aliases. See Support for host allow listing. |
Valid Values | Full path (including filename to allow list) |
Parameter | CMPDB |
Description | Database Type. This parameter is provided for backward compatibility and is set to ORACLE. This should not be altered. |
Valid Values | ORACLE |
Parameter | CM_INSTALL_SAMPLE |
Description | Whether sample code is installed or not. Done at installation time. |
Parameter | COHERENCE_CLUSTER_ADDRESS |
Description | Multicast IP Address for CLUSTERED mode. Specify the multicast IP address that a Socket will listen or publish on. |
Valid Values | Valid values are from 224.0.0.0 to 239.255.255.255. |
Parameter | COHERENCE_CLUSTER_MODE |
Description | Oracle Coherence mode. Coherence may be configured to operate in either development or production mode. These modes do not limit access to features, but instead alter some default configuration settings. For instance, development mode allows for faster cluster startup to ease the development process. The development mode is used for all pre-production activities, such as development and testing. This is an important safety feature because development nodes are restricted from joining with production nodes. Development mode (dev) is the default mode. Production mode (prod) must be explicitly specified when using Coherence in a production environment |
Valid Values | [dev|prod] |
Parameter | COHERENCE_CLUSTER_NAME |
Description | Unique Cache name for Coherence Clusters. |
Valid Values | Any string value. It is recommended to use the SPLENVIRON value, optionally, with the database schema owner as a unique identifier. Example: DEV.SPLADM |
Parameter | COHERENCE_CLUSTER_PORT |
Description | Unique Cache port for the Coherence Cluster. |
Valid Values | Any open relevant port unique to the COHERENCE_CLUSTER_NAME. |
JEE Web Application Server | Not Applicable |
Installation Mode | Not Applicable |
Parameter | CONSOLIDATED_LOG_FILE_PATH |
Description | Specifies the directory for the consolidated log file. |
Valid Values | Full directory path. |
Tier | Web Application Server, Business Application Server, Background Processing, Database. |
Parameter | CORS_HOST |
Description | Specifies the Cross Origin Resource Sharing source host if ENABLE_CORS is set to true. |
Valid Values | Host Address/URL |
Tier | Web Application Server |
Parameter | CORS_PORT |
Description | Specifies the Cross Origin Resource Sharing source host’s port if ENABLE_CORS is set to true. |
Valid Values | Host Port |
Parameter | CORS_SCHEME |
Description | Specifies the Cross Origin Resource Sharing communication scheme to be used if ENABLE_CORS is set to true. |
Valid Values | [http|https] |
Parameter | CSRF_PROTECTION |
Description | Specifies if Cross-Site Request Forgery protection is enabled or disabled. |
Parameter | CUSTOM_SQL_SECURITY |
Description | Specifies if custom SQL security is enabled or disabled. |
Parameter | DBCONNECTION |
Description | Generated Database JDBC string. This is generated from the DBSERVER / DBPORT / DBNAME or DB_OVERRIDE_CONNECTION. As this is generated, it should not be altered. Customers using Native mode installation can replace this connection with JDBC Data Sources, if desired. |
Valid Values | Generated URL |
Tier | Business Application Server, Background Processing, Database. |
Parameter | DBDRIVER |
Description | Database Driver to use. Automatically generated by installation. This should not be altered. |
Parameter | DBNAME |
Description | Oracle Database Instance Name. Customers using Native mode installation can ignore this value if using JDBC Data Sources. |
Valid Values | Valid Database instance name |
Parameter | DBPASS |
Description | Encrypted database user password for the online component of the product. Password for DBUSER. |
Parameter | DBPASS_GEOCODE_WLS |
Description | Encrypted database user password for the GEOCODE integration. Password for DBUSER_GEOCODE. |
Tier | Business Application Server, Database. |
Parameter | DBPASS_MDS |
Description | Encrypted database user password for the SOA Suite Meta Data Service (MDS) integration. Password for DBUSER_MDS. This password was specified as part of the SOA Suite database installation process for the prefix_MDS user. This is only valid for products that include Oracle SOA Suite. This is used for deployment of content to Oracle SOA Suite for integration. |
Parameter | DBPASS_ORASDPM |
Description | Encrypted database user password for the SOA Suite User Message Services (DPM) integration. Password for DBUSER_ORASDPM - DPM Database User. This password was specified as part of the SOA Suite database installation process for the prefix_ORASDPM user. This is only valid for products that include Oracle SOA Suite. This is used for deployment of content to Oracle SOA Suite for integration. |
Parameter | DBPASS_OSB |
Description | Encrypted database user password for the Oracle Service Bus (OSB) integration. Password for DBUSER_OSB - OSB Database User. This password was specified as part of the Oracle Service Bus installation for the OSB database user. This is only valid for products that include Oracle Service Bus. This is used for deployment of content to Oracle Service Bus for integration. This is not used for the Oracle Service Bus Adapters for Oracle Utilities. |
Parameter | DBPASS_SOAINFRA |
Description | Encrypted database user password for the SOA Suite integration. Password for DBUSER_SOAINFRA - SOA Database User. This password was specified as part of the SOA Suite database installation process for the prefix_SOAINFRA user. This is only valid for products that include Oracle SOA Suite. This is used for deployment of content to Oracle SOA Suite for integration. |
Parameter | DBPORT |
Description | Oracle Listener port for connection to the database. Customers using Native mode installation can ignore this value if using JDBC Data Sources. |
Parameter | DBSERVER |
Description | Oracle Database Host Name. Customers using Native mode installation can ignore this value if using JDBC Data Sources. |
Valid Values | Valid Host Name |
Parameter | DBURL_GEOCODE |
Description | Oracle Database JDBC URL used for Geocoding. This is set for products using Oracle Spatial. |
Valid Values | Valid JDBC URL |
Parameter | DBURL_OSB |
Description | Oracle Database JDBC URL for Oracle Service Bus. This is used for deploying content to Oracle Service Bus. |
Parameter | DBURL_SOA |
Description | Oracle Database JDBC URL for Oracle SOA Suite. This is used for deploying content to Oracle SOA Suite. |
Parameter | DBUSER |
Description | Database User, with Read/Write permissions used for pooled connections for online transactions. |
Valid Values | Valid Database User used in installation |
Parameter | DBUSER_GEOCODE |
Description | Database User, with connection to Geocode Database. |
Valid Values | Valid Database User on target database |
Description | Database user password for the SOA Suite Meta Data Services (MDS) integration. This userid was specified as part of the SOA Suite database installation process for the prefix_MDS user. This is only valid for products that include Oracle SOA Suite. This is used for deployment of content to Oracle SOA Suite for integration. |
Valid Values | Valid Database User (prefix_MDS) on target database |
Description | Database user password for the SOA Suite User Messaging Services (DPM) integration. This userid was specified as part of the SOA Suite database installation process for the prefix_ORASDPM user. This is only valid for products that include Oracle SOA Suite. This is used for deployment of content to Oracle SOA Suite for integration. |
Valid Values | Valid Database User (prefix_ORASDPM) on target database |
Description | Database user password for the Oracle Service Bus integration. This userid was specified as part of the Oracle Service Bus database installation process. This is only valid for products that include Oracle Service Bus. This is used for deployment of content to Oracle Service Bus for integration. |
Description | Database user password for the SOA Suite integration. This userid was specified as part of the SOA Suite database installation process for the prefix_SOAINFRA user. This is only valid for products that include Oracle SOA Suite. This is used for deployment of content to Oracle SOA Suite for integration. |
Valid Values | Valid Database User (prefix_SOAINFRA) on target database |
Parameter | DB_OVERRIDE_CONNECTION |
Description | Database JDBC Override string. For customers using Oracle 12c, use a string in the following format to support Pluggable Databases: jdbc:oracle:thin:@//<host>:<port>/<pdbname> Customers using Native mode installation can replace this connection with JDBC Data Sources, if desired. |
Valid Values | Valid JDBC URL. |
Parameter | DESC |
Description | Environment Description. Used for documentation purposes only. |
Valid Values | String Value |
Tier | Not Applicable |
Parameter | DIALECT |
Description | Hibernate Dialect. This is the database dialect used by Hibernate to process database requests. It is automatically generated by the installer and should not be altered. |
Valid Values | Valid Hibernate Dialects |
Parameter | DIRSEP |
Description | Directory Separator. This is an internal setting that sets the directory separator applicable for the platform. It is used by various scripts to set the paths correctly for the operating system. It is automatically generated at installation time and should not be altered. |
Valid Values | Directory Separator character |
Parameter | DOC1BILLSCRIPT |
Description | This setting sets the name of the external printing script used for printing extracts using Oracle Documaker. It is generated by individual products that support this feature. |
Valid Values | Name of supplied script |
Tier | Web Application Server, Business Application Server, Inbound Web Services, Background Processing |
Parameter | DOC1SCRIPT |
Description | This setting sets the name of the generic printing script used for extracts using Oracle Documaker. It is generated by individual products that support this feature. |
Parameter | ENABLE_CORS |
Description | This specifies if OUAF is Cross Origin Resource Sharing enabled for embedded UI. |
Parameter | ENABLE_JMS_GLOBAL_FLUSH |
Description | This specifies if the global JMS flushing is enabled. |
Parameter | ENCODING |
Description | Enables or Disables encryption across the product. By default, encryption is enabled (true) and is recommended to be enabled for all environments. |
Parameter | ENVIRONMENT_ID |
Description | Unique identifier for each environment or copy of the product. This is specified at installation time to link disparate installations into a single environment for management purposes. This setting is used by the Oracle Application Management Pack for Oracle Utilities within Oracle Enterprise Manager to link disparate targets across several hosts into a single Oracle Utilities Environment target. |
Valid Values | Autogenerated |
Parameter | FORCE_HTTP |
Description | Specifies if http protocol needs to be enforced. |
Parameter | FWVERSION |
Description | Oracle Utilities Application Version. This is an internal setting that is generated upon installation of the product, service pack installation or upgrade installation. It is automatically generated at installation time and should not be altered. |
Valid Values | Valid Oracle Utilities Application Framework version |
Parameter | FW_VERSION_NUM |
Description | Oracle Utilities Application Version This is an internal setting that is generated upon installation of the product, service pack installation or upgrade installation. It is automatically generated at installation time and should not be altered. |
Parameter | GIS |
Description | Enables or Disables GIS support within the product. This setting is only used by products that use GIS integration. Setting this value to true enable all other GIS settings. |
Parameter | GIS_URL |
Description | Specifies the GIS JNDI URL used for connections. This setting is only used by products that use GIS integration. This setting is only used if GIS is set to true. |
Valid Values | Valid JNDI URL |
Parameter | GIS_WLSYSPASS |
Description | Encrypted JNDI Password for GIS integration. This setting is only used by products that use GISintegration. This setting is only used if GIS is set to true. |
Valid Values | Valid Encrypted Password |
Parameter | GIS_WLSYSUSER |
Description | Encrypted JNDI User for GIS integration. This setting is only used by products that use GIS integration. This setting is only used if GIS is set to true. |
Valid Values | Valid Encrypted User |
Parameter | GLOBAL_JVMARGS |
Description | Specific additional JVM options for the online component of the product for Oracle JVM (to enable advanced features) |
Valid Values | This is generated |
Parameter | HEADEND_CD_CB |
Description | URI as configure in SOA Suite Configuration Plan for Headend System for the CD_DB interface (Echelon). This setting is only available to products interfacing to head end systems using SOA Suite. |
Valid Values | Valid SOA Suite URI for CD_DB interface. |
Parameter | HEADEND_MR_CB |
Description | URI as configure in SOA Suite Configuration Plan for Headend System for the MR_DB interface (Echelon). This setting is only available to products interfacing to head end systems using SOA Suite. |
Valid Values | Valid SOA Suite URI for MR_DB interface. |
Parameter | HIBERNATE_JAR_DIR |
Description | Location of the Hibernate JAR files. This setting is used by the installer to copy the relevant files to the desired locations for deployment. This setting is only used at installation time but is registered for potential post release use. |
Valid Values | Valid location of Hibernate JAR Files as outlined in the product Installation Guide. |
Tier | Business Application Server, Inbound Web Services, Background Processing. |
Parameter | HIGHVALUE |
Description | High value used for SQL queries. This is autogenerated at installation time. |
Valid Values | This value is automatically generated and should not be altered. |
Parameter | HSTS_MAX_AGE |
Description | Maximum age of strict transport security. |
Ordinality | Optional. Default Value is 31536000. |
Valid Values | Value in seconds. |
Parameter | HSTS_PRELOAD |
Description | Preload of strict transport security. |
Valid Values | [false|true] |
Parameter | HSTS_SUBDOMAINS |
Description | Subdomains that are included in strict transport security. |
Parameter | IWS_JDBC_NAME |
Description | This is the JDBC Data Source connection name used for Inbound Web Services. The JDBC Data Source should be created prior to setting this value using the Configuring JDBC Data Sources instructions. |
Valid Values | Valid fully qualified JNDI name for JDBC Data Source. |
Tier | Inbound Web Services |
Parameter | IWSWAR |
Description | Default Name for Inbound Web Services Application Name. |
Valid Values | Valid Server Application Names |
Parameter | JAVAENCODING |
Description | Encoding string for Java to support appropriate character sets. |
Valid Values | Valid Java Encoding (java.lang). Default: UTF8 |
Parameter | JAVA_HOME |
Description | Location of JDK for use with product |
Valid Values | Valid JAVA_HOME location |
Parameter | JAVA_VENDOR |
Description | JVM Vendor |
Valid Values | Generated and used in other utilities |
Parameter | JAVA_VERSION |
Description | Fully qualified JVM version string |
Parameter | JAVA_VERSION_MAIN |
Description | Abbreviated JVM version string |
Parameter | JDBC_NAME |
Description | This is the JDBC Data Source connection name used for Online channel. The JDBC Data Source should be created prior to setting this value using the Configuring JDBC Data Sources instructions. |
Parameter | JDBC_TIMEOUT |
Description | Disable Cross Site Request Forgery token validation for REST Services. The JDBC Data Source should be created prior to setting this value using the Configuring JDBC Data Sources instructions. |
Valid Values | The value should be in milliseconds, the default is 600000 (10 minutes). |
Parameter | JNDI_GEOCODE |
Description | JNDI name for the Geocode Data Source. This parameter is used with for the Geocode interface. This parameter is only valid for products that use the Geocode interface. |
Valid Values | Valid JNDI for Geocode Data Source |
Tier | Business Application Server, Background Processing, MOB. |
Parameter | JNDI_OSB |
Description | JNDI name for the Oracle Service Bus Data Source. This parameter is used with for the Oracle Service Bus interface. This parameter is only valid for products that ship integration that requires Oracle Service Bus. |
Valid Values | Valid JNDI for Oracle Service Bus Data Source |
Parameter | KS_IMPORT_KEYSTORE_FOLDER |
Description | Keystore import folder. |
Valid Values | Valid location for keystore folder. |
Parameter | LD_LIBRARY_PATH |
Description | Generated Library Path for Windows, Linux and Solaris |
Valid Values | This value is generated by the product installer. |
Parameter | MODULES |
Description | Generated list of modules. This is generated by the product installer. This parameter is provided for backward compatibility as modules installed are now autogenerated from installation records. |
Valid Values | Calculated inside processTemplate.plx. |
Parameter | NLS_LANG |
Description | Globalization Language setting for the database. |
Valid Values | Valid NLS_LANG. Default: AMERICA_AMERICAN. AL32UTF8 |
Tier | Business Application Server, Inbound Web Services, Background Processing, Database. |
Parameter | ONLINE_DISPLAY_HOME |
Description | Location of Print Rendering Software such as Oracle Documaker or Group 1 Doc 1. |
Valid Values | Valid product location of the print rendering software |
Parameter | ONS_JAR_DIR |
Description | Location of Oracle Notification Services Libraries used for RAC Fast Connection Failover support. |
Valid Values | Valid location of ons.jar file. Usually $ORACLE_HOME/opmn/lib |
Parameter | ONSCONFIG |
Description | ONS configuration string used for RAC Fast Connection Failover support. For example: racnode1.my.com:4200,racnode2.my.com:4200 |
Valid Values | ONS configuration string without nodes= prefix. |
Parameter | OPSYS |
Description | Internal variable used for platform specific configurations to be implemented. |
Valid Values | Generated Operating System String |
Parameter | ORACLE_CLIENT_HOME |
Description | Location of Oracle Client Software or Oracle Home. This is used for ONS and/or the Perl runtime. |
Valid Values | Location of Oracle Client Installation. If the Oracle Database software is installed on the same machine, then this can be ORACLE_HOME. |
Parameter | OSB_HOME |
Description | Location of Oracle Service Bus. This is used to deploy Oracle Service Bus content. This setting only applies to products with prebuilt Oracle Service Bus content. This is not used for Oracle Service Bus Adapters. |
Valid Values | Location of Oracle Service Bus installation. |
Parameter | OSB_HOST |
Description | Host Name for Oracle Service Bus. This is used to deploy Oracle Service Bus content. This setting only applies to products with prebuilt Oracle Service Bus content. This is not used for Oracle Service Bus Adapters. |
Valid Values | Host Name for Oracle Service Bus. |
Parameter | OSB_LOG_DIR |
Description | Logging Directory Oracle Service Bus. This is used to deploy Oracle Service Bus content. This setting only applies to products with prebuilt Oracle Service Bus content. This is not used for Oracle Service Bus Adapters. |
Valid Values | Logging directory for Oracle Service Bus content deployment. |
Parameter | OSB_PASS_WLS |
Description | Encrypted password for OSB deployment user (OSB_USER). This is used to deploy Oracle Service Bus content. This setting only applies to products with prebuilt Oracle Service Bus content. This is not used for Oracle Service Bus Adapters. |
Valid Values | Generated Password. |
Parameter | OSB_PORT_NUMBER |
Description | Port number allocated to Oracle Service Bus. This is used to deploy Oracle Service Bus content. This setting only applies to products with prebuilt Oracle Service Bus content. This is not used for Oracle Service Bus Adapters. |
Valid Values | Valid Administration port to use for deployment of content. |
Parameter | OSB_USER |
Description | Administration user used for OSB deployment user. This is used to deploy Oracle Service Bus content. This setting only applies to products with prebuilt Oracle Service Bus content. This is not used for Oracle Service Bus Adapters. |
Valid Values | Valid Administration user to use for deployment of content. |
Parameter | OUAF_DBMS_SCHEDULER_USER |
Description | Database user for DBMS scheduler. |
Valid Values | Database User Name. For example, SCHADM |
Parameter | OWSM_PROTECTION_FOR_REST_SERVICES |
Description | Specifies if Oracle Web Services Manager protection is enabled or disabled for REST services. |
Tier | Web Application Server, Business Application Server, Inbound Web Services. |
Parameter | PERLHOME |
Description | Generated location for Perl runtime. Generated from ORACLE_CLIENT_HOME - Oracle Client Home. |
Valid Values | Generated location for Perl. |
Parameter | SERVER_ROLES |
Description | The server roles are enabled for this installation. |
Valid Values | Install generated |
Tier | Web Application Server, Inbound Web Services, Background Processing. |
Parameter | SERVER_ROLE_BATCH |
Description | Whether this installation is to be used for batch processing |
Parameter | SERVER_ROLE_INTEGRATION |
Description | Whether this installation is to be used for integration (IWS) |
Parameter | SERVER_ROLE_ONLINE |
Description | Whether this installation is to be used for online |
Parameter | SOA_HOME |
Description | Location of Oracle SOA Suite software. This is used to deploy Oracle SOA Suite content. This setting only applies to products with prebuilt Oracle SOA Suite content. |
Valid Values | Valid location of Oracle SOA Suite. |
Parameter | SOA_HOST |
Description | Hostname for Oracle SOA Suite software. This is used to deploy Oracle SOA Suite content. This setting only applies to products with prebuilt Oracle SOA Suite content. |
Valid Values | Valid host name for Oracle SOA Suite. |
Parameter | SOA_PORT_NUMBER |
Description | Port Number for Oracle SOA Suite software. This is used to deploy Oracle SOA Suite content. This setting only applies to products with prebuilt Oracle SOA Suite content. |
Valid Values | Valid port number for Oracle SOA Suite. |
Parameter | SPLADMIN |
Description | Administration OS user used to install the software. Used by utilities to assign ownership and for deployment purposes. |
Valid Values | Valid Administration Account. |
Parameter | SPLADMINGROUP |
Description | Administration OS group used to install the software. Used by utilities to assign ownership and for deployment purposes. |
Valid Values | Valid Administration Group. |
Parameter | SPLApp |
Description | Name of online WAR file used for building purposes |
Valid Values | Valid WAR file name. |
Parameter | SPLDIR |
Description | Home Location of product software. This value must match the corresponding entry in cistab - Global Configuration Files. |
Valid Values | Valid Location of software. Generated by installer. |
Parameter | SPLDIROUT |
Description | Home Location of product output. This value must match the corresponding entry in cistab - Global Configuration Files. |
Valid Values | Valid Location of output. Generated by installer. |
Parameter | SPLOUTPUT |
Description | Location of product output. |
Parameter | SPLSERVICEAPP |
Description | Default Name for Business Application Name. |
Parameter | SPLWEBAPP |
Description | Default Name for Web Application Name. |
Ordinality | Mandatory for Oracle WebLogic implementations |
Parameter | STRICT_TRANSPORT_SECURITY |
Description | Enable or Disable transport layer security. |
Parameter | STRIP_HTML_COMMENTS |
Description | Enable or Disable Stripping comments in generated code. By default, code is commented for ease of extension. If these comments represent a security issue for your site, then they can be stripped out at runtime (true). |
Parameter | TEMPSTORAGE_SPLITFILESIZE |
Description | The size of split files in MB, while transferring a file using file adapter API. |
Valid Values | Valid file size in MB. Default is 50. |
Parameter | TOP_VERSION |
Description | Product Version identifier string used by utilities and upgrade scripts. |
Valid Values | Generated by installer and should not be altered manually. |
Parameter | TOP_VERSION_NUM |
Description | Product Version identifier number used by utilities and upgrade scripts. |
Parameter | WEB_ADMIN_SERVER |
Description | Name of the web admin server. |
Valid Values | Server Name |
Parameter | WEB_APP |
Ordinality | Mandatory for WebSphere implementations |
Parameter | WEB_APPVIEWER_FORM_LOGIN_ERROR_PAGE |
Description | Error Page used for invalid AppViewer Login. |
Valid Values | Valid JSP for error pages |
Parameter | WEB_APPVIEWER_FORM_LOGIN_PAGE |
Description | Login Page used for AppViewer Login. |
Valid Values | Valid JSP for login |
Parameter | WEB_APPVIEWER_PRINCIPAL_NAME |
Description | Principal Name for AppViewer |
Valid Values | Valid Principal Name |
Parameter | WEB_APPVIEWER_ROLE_NAME |
Description | Role Name for AppViewer |
Valid Values | Valid Role Name |
Parameter | WEB_CONTEXT_ROOT |
Description | Web Context for product |
Valid Values | Valid context. Default: spl |
Parameter | WEB_DEPLOY_APPVIEWER |
Description | Whether the AppViewer application is included in the online EAR file. A value of true adds the appViewer to the online EAR file. A value of false does not add the appViewer content to the online EAR file. Note: If the appViewer is not deployed the online administration functions that use the appViewer will not display this content. It is recommended to set this value to false for non-development environments. Note: AppViewer has been deprecated and will be removed from a future release. |
Parameter | WEB_ENABLE_HEALTHCHECK |
Description | Enable the system healthcheck function used by the Oracle Application Management Pack for Oracle Utilities available from Oracle Enterprise Manager. |
Parameter | WEB_FORM_LOGIN_ERROR_PAGE |
Description | Error Page used for invalid online Login. |
Parameter | WEB_FORM_LOGIN_PAGE |
Description | Login Page used for online Login. |
Parameter | WEB_HELP_FORM_LOGIN_ERROR_PAGE |
Description | Error Page used for invalid Help Login. |
Parameter | WEB_HELP_FORM_LOGIN_PAGE |
Description | Login Page used for Help Login. |
Parameter | WEB_ISAPPVIEWER |
Description | Enable or Disable AppViewer from deployment. The use of AppViewer is recommended for appropriate non-production environments only. |
Parameter | WEB_ISDEVELOPMENT |
Description | Enable or Disable Development on this product environment. This setting assumes that the Oracle Utilities SDK. |
Parameter | WEB_IWS_MDB_RUNAS_USER |
Description | The default product user the MDB uses to run its interface. This value is used if no JMS credentials are provided on the message header. A blank value, the default, for this parameter disables the function and assumes all JMS messages will include their credentials in the head of the message. |
Valid Values | Blank (not enabled) or a valid product authorization userid (not login id). |
Parameter | WEB_IWS_SUPER_USERS |
Description | Default product user used for authorization for Inbound Web Services. This value is used for internal calls used for Inbound Web Services. |
Valid Values | Blank (not enabled) or a valid product authorization userid (not login id) |
Parameter | WEB_JMX_RMI_PORT_PERFORMANCE |
Description | Port number for JMX monitoring for Online monitoring. |
Valid Values | Valid open port number for monitoring. |
Parameter | WEB_L2_CACHE_MODE |
Description | Enables (on) or disables (off) Level 2 cache for online submission. Used for development purposes where online submission cache is off. Note: Some batch processes require L2 Cache to be disabled. Refer to individual job documentation for details. |
Valid Values | [on|off] |
Tier | Web Application Server, Background Processing. |
Parameter | WEB_MAXAGE |
Description | Set the duration (in seconds) to store page structures from the product, in the Client Cache, on the client browser. |
Valid Values | See maxAge - Max Age for pages for valid values. |
Parameter | WEB_MAXAGEI |
Description | Set the duration (in seconds) to store images, in the Client Cache, from the product on the client browser. |
Valid Values | See maxAgeI - Max Age for Images for valid values. |
Parameter | WEB_PRELOADALL |
Description | Enable or Disable preload of pages at startup. This determines the scope of any reload. A value of false (default) only preloads the Main menu only. A value of true preloads all functions on all menus. A value of true will lengthen the startup process. |
Parameter | WEB_PRINCIPAL_NAME |
Description | Principal Name for online application. |
Valid Values | Valid Principal Name. Default: cisusers |
Parameter | WEB_ROLE_NAME |
Description | Role Name for online application |
Valid Values | Valid Role Name. Default: cisusers |
Parameter | WEB_SERVER_HOME |
Description | Generic location of Web Application Server. This should match the value for WL_HOME which is set for the Oracle WebLogic installation used for the product. |
Valid Values | Home location of Web Application Server software |
Parameter | WEB_SERVER_VERSION |
Description | Full Version of Oracle WebLogic. Used for utilities to ensure correct templates are used. |
Valid Values | Generated by installer. |
Parameter | WEB_SERVER_VERSION_MAIN |
Description | Substring Version of Oracle WebLogic. Used for utilities to ensure correct templates are used. |
Parameter | WEB_WLAUTHMETHOD |
Description | JEE Authorization Method implemented. |
Valid Values | Valid Values: FORM (Default) - Use login forms BASIC - Use Operating System Login CLIENT-CERT - Client Certificate or external authentication |
Parameter | WEB_WLHOST |
Description | Host Name for Oracle WebLogic Install. |
Valid Values | Valid Host Name. |
Parameter | WEB_WLPAGECHECKSECONDS |
Description | Interval, in seconds, to force recompilation for server JSP's. This is used for Oracle WebLogic customers only. This setting is designed to be altered for development environments. The default is recommended for all other environments. |
Valid Values | Valid Recompile time. Default: 43200 |
Parameter | WEB_WLPORT |
Description | Port number for environment for online system. |
Ordinality | Optional. Value should not be populated if WEB_WLSSLPORT is populated. |
Valid Values | Valid open port number. Example: 6500 |
Parameter | WEB_WLSSLPORT |
Description | SSL Port number for environment for online system. |
Ordinality | Optional. Value should not be populated if WEB_WLPORT is populated. |
Parameter | WEB_WLSSYSPASS |
Description | Encrypted Oracle WebLogic JNDI Password used for JNDI lookups. |
Valid Values | Valid JNDI Password. |
Parameter | WEB_WLSSYSUSER |
Description | Oracle WebLogic JNDI User used for JNDI lookups. |
Valid Values | Valid JNDI User. |
Parameter | WEB_WLS_SVRNAME |
Description | Oracle WebLogic Server Name. |
Valid Values | Valid Server Name. Default: myserver |
JEE Web Application Server | WLS |
Parameter | WLS_ADMIN_PORT |
Description | Oracle WebLogic Administration Port. Only supplied if Administration port differs from application port. Oracle WebLogic Server Name. This is used for Oracle WebLogic customers only and embedded installations only. |
Valid Values | Valid Port Number. Default: Value of WEB_WLPORT - Web Server HTTP Port. |
Parameter | WLS_CLUSTER_NAME |
Description | Oracle WebLogic Cluster Name for clustered environments. This value must be set for customers using the Application Management Pack for Oracle Utilities to link the cluster target with the product. |
Valid Values | Valid Cluster Name. |
Parameter | WLS_DIAGNOSTIC_CONTEXT_ENABLED |
Description | This enables (true) or disables (false) ECID Support. |
Parameter | WLS_DOMAIN_HOME |
Description | Domain Home directory for installation. Used if installation has multiple domains installed. |
Valid Values | Valid Domain Home |
Parameter | WLTHINT3CLIENT_JAR_DIR |
Description | Location of Oracle WebLogic thin Client for JMX and other interfaces. Used for integration to Oracle products for monitoring. |
Valid Values | Valid location of wlthint3client.jar |
Tier | Web Application Server, Inbound Web Services. |
Parameter | WL_HOME |
Description | Home directory of Oracle WebLogic. |
Valid Values | Valid console user. |
Parameter | XAI_DBPASS |
Description | Encrypted database user password for the Inbound Web Services component of the product. |
Tier | Inbound Web Services, Database. |
Parameter | XAI_DBUSER |
Description | Database User, with Read/Write permissions used for pooled connections for Inbound Web Services transactions. |
Parameter | XQUERIES_TO_CACHE |
Description | Size of XQuery/XPath Cache in number of queries. Increasing the cache size may increase memory requirements for the product. This sets the value of com.oracle.XPath.LRUSize - XPath Cache in the spl.properties file |
Valid Values | Defaults from templates (-1 - Unlimited in size) |
Parameter | XQUERY_CACHE_FLUSH_TIMEOUT |
Description | Length of time in seconds that XQuery and XPath queries are cached and set the value of com.oracle.XPath.flushTimeout - XPath Flush in the spl.properties file. |
Valid Values | Defaults from templates (0 - Never flush is the default) |
Tier | Business Application Server, Inbound Web Services, Background Processing |
