Cross-Reference To The Remaining Chapters
The table in the previous section describes the order in which you should enter your control tables. These tables are described at length in the following chapters.
• Refer to
Defining Customer Options for a discussion of the control tables affecting persons, accounts and service agreements.
• Refer to
Rates for a discussion of the control tables affecting your rates.
• Refer to
Defining Algorithms for a discussion of the control tables affecting the algorithms referenced on many control tables.
• Refer to
Defining SA Relationships for a discussion of the control tables affecting the relationships between service providers.
• Refer to
Statements for a discussion of the tables affecting the statement setup options for your customers.
Parent topic
