NMS Outage Integration - Master Configuration
The integration with Oracle Utilities Network Management System (NMS) requires the setup of master configuration data that controls the processing of master data synchronization and outage management operations.
Navigate to > >
Set up the NMS Outage Integration Master Config: This master configuration relates to the outage call and outage query integration with NMS.
Refer to the embedded help for more details on how each section is configured.
Parent topic
