Setting Up The System To Enable Outage Integration
The following section provides an overview of how to enable the integration between Oracle Utilities Customer Care and Billing and Oracle Utilities Network Management System.
External System Setup
Define Characteristic Types
Schema Constants - Feature Configuration
NMS Outage Integration - Master Configuration
Outage Notification Preferences
Parent topic
Outage System Integration
This site works best with JavaScript enabled
