Champion Template$Challenger Template$Percentage(1-100). You need only set up options of this type if your implementation implements
Champion / Challenger functionality. Options of this type are entered in the format A$B$nnn where A is the collection process template of the champion template, B is the collection process template of the challenger template, and C is the percent of the time that the system should create the challenger template. The collection monitor uses this option to override the champion collection process template X% of the time with the challenger template. You may enter any number of these options (but only one per Champion Template).
