SA Type - Algorithms (NBB)
The SA type
algorithms defined above must be set up:
• The Non-Billed Budget Credit Transfer algorithm created above should be specified for the Bill Completion system event (not used on unmonitored Non-Billed Budgets).
• The Break Non-Billed Budget SA algorithm created above should be specified for the Break NBB SA system event.
• The Non-Billed Budget Process Scheduled Payment algorithm created above should be specified for the Process NBB Scheduled Payment system event (not used on unmonitored non-billed budgets).
• The Non-Billed Budget SA Renewal algorithm created above should be specified for the SA Renewal system event.
• If you created the Automatic SA Activation algorithm above, it should be specified for the SA Creation system event.
• The Non-Billed Budget SA Activation algorithm created above should be specified for the SA Activation system event.
• If you created the Automatic SA Stop algorithm above, it should be specified for the SA Stop Initiation system event.
• The Stop Non-Billed Budget algorithm created above should be specified for the SA Stop system event.
Parent topic
