Navigating to Related NUS Extension
When designing the types of notifications your organization may receive, you must determine where you plan to store the detailed information related to the incoming transaction: as context linked to the NUS, as characteristics linked to the NUS or by using an extension record.
Fastpath:
Refer to
Process X - Populate Notification Upload Staging for information about the different options available.
If you choose to capture the detailed information in a new extension record with a new user interface, then in order to be able to drill down to the related extension record, the following steps are required.
• Add a new
lookup value for your new extension record for the field NT_UP_EXTSN_FLG. (This step is needed regardless of whether you want to drill down to the related record.)
• Add a
navigation option pointing to the appropriate navigation key for your new transaction. This navigation option must reference a usage type of notification upload type.
• Indicate the appropriate lookup value and navigation option on the appropriate notification upload type.
Parent topic
