Setting Up Notification Download Profiles
A notification download profile controls how the system routes notifications to service providers. You associate a notification download profile with one or more service providers. Whenever a notification is sent to a service provider, the system uses the notification download profile to determine the interface method and the format of notifications.
Open > > to define your notification download profiles.
Fastpath:
Description of Page
Define a unique ID and Description for each Download Profile.
Use NDS Extract Process to define the background process that creates notification download records and interfaces them out of the system.
The information in the scroll controls how the Extract Process formats an interface record for each Notification Download Type. In addition to defining a Description and Comments, you must define the Processing Method. The valid values are XAI and Batch.
If your processing method is Batch, you need to define the Notification Format Algorithm that actually formats the interface record. If you haven't done so already, you must set up this algorithm in the system. To do this:
• On this algorithm, reference an Algorithm Type that is associated with workflow event failure. The system comes supplied with several sample algorithm types that should be used as a sample if you have to write a new algorithm type.
If your processing method is XAI, you may define one or more
XAI Route Types. The
XAI Route Type describes how the message should be formatted and the destination of the message.
Parent topic
