System Event | Optional / Required | Description |
Cancel Logic | Required | This algorithm is executed to cancel an overdue event. Refer to How Are Events Canceled for the details. |
Event Activation | Required | This algorithm is executed to activate an overdue event on its trigger date. Refer to Overdue Events Can Do Many Things and How and When Events Are Activated for the details. |
Event Information | Optional - only used if you want to override an overdue event's info string | This algorithm is executed to construct an overdue event's override info string. Refer to Overdue Event Information Is Overridable for the details. |
Monitor Waiting Events | Optional - only used if events of this type can enter the Waiting state | This algorithm is invoked by the Overdue / Cut Event Manager for events in the Waiting state. Refer to Some Events Wait For Something Before Completing for the details. |
