Setting Up The Batch Scheduler
The following topics summarize how to set up the system to enable the scheduling of job streams.
Create A Workflow Event Type - Activation Algorithm For Every Batch Job
Create A Workflow Event Type For Every Batch Job
Create A Workflow Process Template For Every Job Stream
Set Up A Work Calendar
Set Up A Job Stream Creation Schedule For Each Job Stream
Set Up Characteristic Types
Set Up A User ID For Batch Jobs
Set Up A Feature Configuration
Parent topic
Defining Batch Schedule Options
This site works best with JavaScript enabled
