Defining Batch Schedule Options
The topics in this section describe how to set up the system to periodically execute batch job streams.
The batch scheduler is optional. Setting up the batch scheduler is only necessary if your organization uses the product's batch scheduler. If your organization uses a third party tool to manage the periodic execution of batch jobs, this section is not applicable.
Separate module. Batch scheduler functionality is associated with separate Workflow Scheduling module. If this module is not applicable to your business you may turn it off. Refer to
Turn Off A Function Module for more information.
Parent topic
