The Big Picture of Scheduling Batch Jobs
The following points provide an overview of how batch jobs are scheduled to run periodically.
Technical Implementation Of The Batch Scheduler
Job Stream, a Definition
A Workflow Process Is Created Each Time A Job Stream Executes
A Workflow Process Template Defines The Batch Jobs In A Job Stream
How To Start A Job Stream
Activating A Workflow Event Causes A Batch Run To Be Submitted
Workflow Event Status Reflects The Status Of The Batch Run
Parent topic
Defining Batch Schedule Options
This site works best with JavaScript enabled
