Clear FT Balance Control
In the previous step, the system created a balance control and links it to the FT's. If the balance control's balances are consistent with the amount of receivables being transferred into the system, you should run the Clear FT's Balance Control program. This program simply resets the Balance Control column on the FT so that the FT's can be included in a balance control (see the last step below) after they have been transferred to production. Note: the batch control ID of CNV-BCG is used to request this process.
Submitting this process. You submit this process in the staging database. Refer to
Reset Balances for a description of this process and its parameters.
Parent topic
