Recommendations To Speed Up Validation Programs
The following points describe ways to accelerate the execution of the validation programs:
• Ensure that statistics are recalculated after data has been inserted into the staging tables. For Oracle users, we strongly recommend using the Oracle-provided PL/SQL package to generate statistics rather than the analyze command.
• Execute shorter running validation processes (e.g., less records) first so that the error data can be analyzed while other processes are busy running.
• Remember that the
object validation programs can be run in "validate every n th row". We recommend running these programs using a largish value for this parameter until the pervasive problems have been rectified.
Parent topic
