Field | Size | Description |
SA ID | X10 | The unique identifier of the service agreement |
Payoff Balance Sign | X1 | Positive or Negative value indicates debit or credit balance respectively |
Payoff Balance | N15.2 | The SA's payoff balance (how much the customer really owes). |
Current Balance New Charge Sign | X1 | Positive or Negative value indicates debit or credit balance respectively |
Current Balance - New Charge | N15.2 | The amount of the SA's current balance that is considered a new charge, i.e., it hasn't started aging yet. |
Current Balance Amount 1 Sign | X1 | Positive or Negative value indicates debit or credit balance respectively |
Current Balance - Amount 1 | N15.2 | The amount of the SA's current balance that is X days old (X is defined in the next field) |
Age of Current Balance - Amount 1 | N3 | The number of days old the prior field is (if you keep your debt in "buckets" as opposed to knowing the exact number of days it has aged, you will have to choose an exact age). Set this value to zero if the value of amount 1 should be considered a "new charge" (i.e., it should only start aging when it is swept onto the next bill produced for the SA's account) |
Current Balance Amount 2 Sign | X1 | Positive or Negative value indicates debit or credit balance respectively |
Current Balance - Amount 2 | N15.2 | The amount of the SA's current balance that is X days old (X is defined in the next field) |
Age of Current Balance - Amount 2 | N3 | The number of days old the prior field is (if you keep your debt in "buckets" as opposed to knowing the exact number of days it has aged, you will have to choose an exact age) |
Current Balance Amount 3 Sign | X1 | Positive or Negative value indicates debit or credit balance respectively |
Current Balance - Amount 3 | N15.2 | The amount of the SA's current balance that is X days old (X is defined in the next field) |
Age of Current Balance - Amount 3 | N3 | The number of days old the prior field is (if you keep your debt in "buckets" as opposed to knowing the exact number of days it has aged, you will have to choose an exact age) |
Current Balance Amount 4 Sign | X1 | Positive or Negative value indicates debit or credit balance respectively |
Current Balance - Amount 4 | N15.2 | The amount of the SA's current balance that is X days old (X is defined in the next field) |
Age of Current Balance - Amount 4 | N3 | The number of days old the prior field is (if you keep your debt in "buckets" as opposed to knowing the exact number of days it has aged, you will have to choose an exact age) |
Current Balance Amount 5 Sign | X1 | Positive or Negative value indicates debit or credit balance respectively |
Current Balance - Amount 5 | N15.2 | The amount of the SA's current balance that is X days old (X is defined in the next field) |
Age of Current Balance - Amount 5 | N3 | The number of days old the prior field is (if you keep your debt in "buckets" as opposed to knowing the exact number of days it has aged, you will have to choose an exact age) |
