MRUP-PRG - Purge Meter Read Upload Objects
Completed meter read upload staging objects should be periodically purged from the system by executing the
MRUP-PRG background process. This background process allows you to purge all Completed meter read upload staging objects older than a given number of days.
We want to stress that there is no system constraint as to the number of Completed meter read upload objects that may exist. You can retain these objects for as long as you desire. However we recommend that you periodically purge Completed meter read upload objects as they exist only to satisfy auditing and reporting needs.
Parent topic
