Field Activity - Log
Use this page to view and add log records for a field activity. Open this page using > > > and navigate to the Log page.
Description of Page
The Log grid displays log entries that audit the progress of a field activity. You cannot modify or delete log entries that have been created by the system.
You can manually add a log entry of type User.
The Log grid displays the following information:
Date/Time Displays the date and time when the log entry was created.
Log Type Indicates the entry event for which the log entry was created. The log type for log entries created online is User. Refer to the
FA Log Entry Events table below for information about log types provided for log entries that may be created by sample plug-ins.
The values for the log type are customizable using the Lookup table. This field name is FA_LOG_TYP_FLG.
Details Contains user-specified or system-generated information about the log entry.
User Displays the user who caused the log entry to be created.
Sequence Displays the sequence that makes up part of the unique identifier of this log record (together with the Field Activity ID).
Parent topic
