Log Type | Generated By | Content of Details |
Appointment Book - Negative Acknowledgement | FA Response> application service for a negative response to Appointment Book NDS message. | Negative Acknowledgment. Message ID (%1) - %2. Error (%3) %4 Where %1 is message ID %2 is the Notification Download Type description %3 and %4 are the external message code and its corresponding base message category/number, if the external message code has been specified. |
Appointment Booked | FA integration algorithm | Appointment booked for <appointment start date/time > - <appointment end date/time>. |
Appointment Canceled | FA integration algorithm | Appointment for <appointment start date/time > - <appointment end date/time> has been canceled. |
Appointment Canceled - Negative Acknowledgement | FA Response application service for a negative response to any Appointment Cancellation NDS message. | Negative Acknowledgment. Message ID (%1) - %2. Error (%3) %4 Where %1 is message ID %2 is the Notification Download Type description %3 and %4 are the external message code and its corresponding base message category/number, if the external message code has been specified. |
External Message Received | FA completion application service if action is Update Log | Message received from %1. Message text: %2 Where %1 is the description of the external system feature configuration %2 is the message sent from the external system. |
FA External ID Change | FA integration algorithm | FA External ID changed from <FA External ID - Before Change> to <FA External ID - After Change> |
FA Intermediate Status Change | FA integration algorithm | FA Intermediate Status changed from <Intermediate Status Description - Before Change> to <Intermediate Status Description - After Change> |
FA Status Change | FA integration algorithm | FA Status changed from <Status Description - Before Change> to <Status Description - After Change> |
Order Cancellation - Negative Acknowledgement | FA Response application service for a negative response to FA Cancellation NDS message. | Negative Acknowledgment. Message ID (%1) - %2. Error (%3) %4 Where %1 is message ID %2 is the Notification Download Type description %3 and %4 are the external message code and its corresponding base message category/number, if the external message code has been specified. |
Order Cancellation Confirmed | FA Response application service for a positive response to FA Cancellation NDS message | Positive Acknowledgment. Message ID (%1) - %2. Where %1 is message ID and %2 is the description of the NDS type of the original outgoing message. |
Order Change - Negative Acknowledgement | FA Response application service for a negative response to FA Changed NDS message. | Negative Acknowledgment. Message ID (%1) - %2. Error (%3) %4 Where %1 is message ID %2 is the Notification Download Type description %3 and %4 are the external message code and its corresponding base message category/number, if the external message code has been specified. |
Order Change Confirmed | FA Response> application service for a negative response to Appointment Book NDS message. | Positive Acknowledgment. Message ID (%1) - %2. Where %1 is message ID and %2 is the description of the NDS type of the original outgoing message. |
Order Completion | FA completion application service | FA is completed by External System |
Order Creation - Negative Acknowledgement | FA Response> application service for a negative response to Appointment Book NDS message. | Negative Acknowledgment. Message ID (%1) - %2. Error (%3) %4 Where %1 is message ID %2 is the Notification Download Type description %3 and %4 are the external message code and its corresponding base message category/number, if the external message code has been specified. |
Order Creation Confirmed | FA Response> application service for a negative response to Appointment Book NDS message. | Positive Acknowledgment. Message ID (%1) - %2. Where %1 is message ID and %2 is the description of the NDS type of the original outgoing message. |
Order Reschedule - Negative Acknowledgement | FA Response> application service for a negative response to Appointment Book NDS message. | Negative Acknowledgment. Message ID (%1) - %2. Error (%3) %4 Where %1 is message ID %2 is the Notification Download Type description %3 and %4 are the external message code and its corresponding base message category/number, if the external message code has been specified. |
Order Reschedule Confirmed | FA Response> application service for a negative response to Appointment Book NDS message. | Positive Acknowledgment. Message ID (%1) - %2. Where %1 is message ID and %2 is the description of the NDS type of the original outgoing message. |
Outage Call Interfaced | Processing Outage Call NDS message | Outage call has been sent. |
