Reproducing The Field Order Print Flat File
If you use the method of extracting to a flat file, you can reproduce the flat file at any time. Simply request the
FODL
process and specify the run number associated with the historic run.
Parent topic
Printing Field Orders
This site works best with JavaScript enabled
