Generate (Bill Segment)
Click the Generate button to create a new a bill segment.
This button is enabled when either of the following conditions is true:
• You are in add mode (i.e., you are not displaying an existing bill segment) and you have selected an Account ID, Bill ID and SA ID.
• You are displaying a bill segment that is Incomplete, Error, or Freezable. Refer to
Bill Segment Lifecycle for more information about these status values.
When clicked, the Generate window opens.
You must specify the following parameters to generate a new bill segment:
• Accounting Date is used to define the financial period to which the new bill segment's financial transaction will be booked. The current date defaults when the window opens.
• Turn on Allow Estimates if the system is allowed to estimate consumption if it can't find a meter read.
• If the service agreement uses meter reads, use the Billing Option to control how the system retrieves meter reads that appear on the bill. Choose Use Cut off Date if the meter reads must exist on the Cutoff Date (defined above). Choose Use Schedule if you want the service agreement's service point(s) service cycle schedule to control the meter reads that are used (the schedule effective on the cutoff date is used to select the meter reads).
After specifying the above parameters, click the Calculate button to create a new bill segment for the bill.
If there are no errors, the
Bill Segment Freeze Option on the
installation option controls the next step:
• If this option is set to Freeze At Bill Completion, return to
Bill - Main (using the bill context menu) and click the
Freeze / Complete button.
• If this option is set to Freeze At Will, click the
Freeze button and, if everything looks clean, return to
Bill - Main and click the
Complete button.
Parent topic
