Auditing Your TOU Pricing Bill Lines
Just as with interval pricing rate components, TOU pricing rate components may also use an audit algorithm to enable a user to view the details of the calculations.
Refer to
Interval Billing Calculation Details to view the results of calling an audit algorithm.
Refer to
Setting Up TOU Pricing Rate Components for more information related to linking an audit algorithm to your rate component.
Warning:
Snapshots of the data used to generate a bill are not taken. Rather, auditing your TOU pricing bill lines rely on the interval data and classic TOU mapping data tables. As a result,
data records should not be changed. To correct data, you should add a new data set. Refer to
How To Correct a Data Set in Error for more information.
Parent topic
