Determining What TOU Data To Derive
Refer to
Determining What Interval Data To Derive for detail about ensuring that no gaps exist and ensuring that the algorithms are always using the latest data for derivation.
one difference between the base TOU creation algorithms and the base interval derivation algorithms is that the TOU creation algorithms do not use a Number of Days to Process. This is because the base algorithm processes contract option events and the volume of contract option events in the system is not as high as the volume processed by the interval data derivation algorithms.
Parent topic
