Interval Billing Calculation Details
When a bill is produced with calculation lines resulting from interval pricing rate components or TOU Pricing rate components, it's likely that a CSR may want to view the calculation detail to verify that this was done correctly.
Fastpath:
In order to view the details of the calculation of a bill, the interval pricing rate component and TOU pricing rate components must indicate an audit algorithm. Refer to
Auditing Your Interval Pricing Bill Lines for more information.
Once you have a bill generated, go to > > > and navigate to the Calc Lines page. Locate the lines that were produced as a result of an interval pricing rate component. A drill down button appears in the first column.
When you click the drill down for a given line, you are taken to a page that shows details for the calculation of this line. If your bill line was calculated using an interval pricing rate component, you are taken to the interval pricing details page. If your bill line was calculated using a TOU pricing rate component, you are taken to the TOU pricing details page.
Parent topic
