Process IB-SPDB - SA Interval Profile Data Creation
This process derives interval data for accounts in the system. Only accounts that have at least one interval service agreement with derivable profiles linked to it are processed. A 'derivable' profile is an SA Owned profile where this SA is the owner AND the profile type indicates an "Interval Data Creation" derivation algorithm. Interval data for service agreements linked to the account are derived in
billing processing sequence order as defined on their
SA type.
Refer to
Determining What Interval Data To Derive and
Start and End Times for Billing for information about which records are processed by the algorithm.
For each service agreement, the interval data creation algorithms are executed in creation priority order. Refer to
Setting Up Interval Profile Types for more information about defining Interval Data Creation algorithm for an interval profile type.
This process supports
Force Derivation and passes the related input parameters to the data derivation algorithms.
This process is designed to run in parallel threads. Every thread processes a range of accounts.
Any errors detected during this process cause the new data set to be created in Error status and an entry to be written to the
Interval Data Exception table. You can fix these errors by canceling the newly created data set and fixing the source of the problem. Refer to
How to Correct a Data Set in Error for more information.
Parent topic
