Process IB-STDB - SA TOU Data Creation
This process derives classic TOU map data for accounts in the system. Only accounts that have at least one interval service agreement with derivable classic TOU maps linked to it are processed. A 'derivable' map is an SA Owned map where this SA is the owner AND the map type indicates a "TOU Data Creation" algorithm. TOU map data for service agreements linked to the Account are derived in
billing processing sequence order as defined on their
SA type.
For each service agreement, the classic TOU Map Creation algorithms are executed in creation priority order. Refer to
Setting Up Classic TOU Map Types for more information about defining a TOU Data Creation algorithm for a classic TOU map type.
This process supports
Force Derivation and passes the related input parameters to the data creation algorithms.
This process is designed to run in parallel threads. Each thread processes a range of accounts.
Any errors detected during this process cause the new data set to be created in Error status and an entry to be written to the
TOU Data Exception table. You can fix these errors by canceling the newly created data set and fixing the source of the problem. Refer to
How to Correct a TOU Data Set in Error for more information.
Parent topic
