Rate Component - Eligibility
This page is used to define the conditions under which a rate component will be applied. If you don't specify any Eligibility Criteria Groups, the system assumes the rate component should be applied (meaning that a rate component is eligible by default).
Fastpath:
Refer to The Big Picture Of Rate Component Eligibility for more information.
Open this page using Menu > Rates > Rate Component Classic > Search and navigate to the Eligibility page.
Description of Page
Rate Component contains a concatenation of basic information about the rate component. This information only appears after the rate component has been added to the database. The adjacent up and down arrows cause the rate component immediately before or after this rate component to be displayed.
Warning:
The following information is not intuitive; we strongly recommend that you follow the guidelines under The Big Picture Of Rate Component Eligibility before attempting to enter this information.
The Eligibility Criteria Group scroll contains one entry for each group of eligibility criteria. The following fields may be defined for each group:
Use Sequence to control the relative order in which the group is executed when the system determines if the rate component should be applied (smaller numbers are executed before larger numbers).
Use Description and Long Description to describe the criteria group.
Use If Group is True to define what should happen if the eligibility criteria (defined in the following grid) return a value of True.
Choose Apply Rate Component if this rate component should be executed.
Choose Check Next Group if the next criteria group should be checked.
Choose Skip Rate Component if this rate component should NOT be executed.
Use If Group is False to define what should happen if the eligibility criteria (defined in the following grid) return a value of False.
The grid that follows contains the rate component's eligibility criteria. Think of each row as an "if statement" that can result in the related eligibility group being True or False. For example, you might have a row that indicates the customer is eligible for the rate component if the customer's birth date equates to that of a senior citizen. The following bullets provide a brief description of each field on an eligibility criterion. Please refer to Defining Logical Criteria for several examples of how this information can be used.
Use Sequence to control the order in which the criteria are checked.
Use Criteria Field to define the field to compare:
Choose Characteristic if you want to compare a characteristic value that resides on any of the following to a given value (use the adjacent fields to define the object on which the characteristic resides and the characteristic type):
The service agreement being billed
The service agreement's account
The main person linked to the service agreement's account
The characteristic premise linked to the service agreement
One of the service points linked to the service agreement (selected at random)
The bill segment's bill
In addition, you can use a characteristic value that is derived while the rate is being calculated (characteristic values can be created by SQ rules, register rules and many other rate component algorithms)
For effective-dated characteristics, the system selects the characteristic value effective on the start date of the bill segment consumption period. Refer to Determine The Consumption Period For Metered Service for information about how the consumption period is calculated before applying the rate.
Get the most effective characteristic value for the given characteristic type and bill segment start date
Choose Rate Component Value if you want to compare the final value of an earlier rate component to a given value. Push the adjacent search button to select the rate component's sequence number.
Choose Service Quantity if you want to compare the final value of a service quantity to a given value. Push the adjacent search button to select the service quantity's UOM / TOU / SQI.
Choose Algorithm if you want to compare anything other than the above options. Push the adjacent search button to select the algorithm that is responsible for retrieving the comparison value.
Use Criteria Comparison to define the method of comparison:
Choose Algorithm if you want an algorithm to perform the comparison and return a value of True, False or Insufficient Data.
Choose any other option if you want to compare the Criteria Field using a logical operator. The following options are available:
Use >, <, =, >=, <=, <> (not equal) to compare the Criteria Field using standard logical operators. Enter the comparison value in the adjacent field.
Use In to compare the Criteria Field to a list of values. Each value is separated by a comma. For example, if a field value must equal 1, 3, or 9, you would enter a comparison value of 1,3,9.
Use Between to compare the Criteria Field to a range of values. For example, if a field value must be between 1 and 9, you would enter a comparison value of 1,9. Note, the comparison is inclusive of the low and high values.
The comparison value field expects the comma as a delimiter between values. This means that if the values involve decimals, the comma cannot be used as a decimal symbol regardless of what your implementation has set up in your display profile. For decimal values, use " . " as the decimal symbol.
The next three fields control whether the related logical criteria cause the eligibility group to be considered True or False:
Use If True to control what happens if the related logical criterion returns a value of True. You have the options of Group is true, Group is false, or Check next condition. If you indicate Group is true or Group is false, then the rate component will be Skipped or Applied based on the values defined above in If Group is False and If Group is True.
Use If False to control what happens if the related logical criterion returns a value of False. You have the options of Group is true, Group is false, or Check next condition. If you indicate Group is true or Group is false, then the rate component will be Skipped or Applied based on the values defined above in If Group is False and If Group is True.
Use If Insufficient Data to control what happens if the related logical criterion returns a value of "Insufficient Data". You have the options of Group is true, Group is false, or Check next condition. If you indicate Group is true or Group is false , then the rate component will be Skipped or Applied based on the values defined above in If Group is False and If Group is True.
