Setting Up a Component-Based Rate Schedule
A primary rate schedule is setup for every rate that you offer to your customers. A subsidiary rate schedule is setup to encapsulate common rate components shared by multiple primary rate schedules. Rate schedules are defined using the pages described in this section.
A rate schedule isn't complete without rate versions and rate components. Refer to
All Component-Based Rates Share A Common Structure for information about how you must also create rate versions and rate components for every rate schedule.
Parent topic
