Setting Up Register Rules
Warning:
Do NOT attempt to set up register rules until you have a very good understanding of what your meters measure and how your rates charge for this consumption. In addition, you should completely understand the concepts described in
When and How to Manipulate Measured Consumption before creating these rules.
To set up register rules, choose > > > .
Description of Page
Enter a unique Register Rule ID and a Description for the register rule.
Enter Comments that describe, in detail, what the rule does.
Select the Algorithm that controls how the system manipulates the consumption supplied to the rate. Define the Parameters to be used by the register algorithm.
The following table indicates the algorithms that are supplied with the system, its Algorithm Type and how each register algorithm uses its parameters.
Parent topic
