Base Package Register Rules
If the register rule algorithms that are supplied with the base package are not sufficient for your rating requirements, you will have to write a new register rule algorithm. Refer to How to Add a New Register Rule for how to do this.
Register Algorithm
Algorithm Type
What It Does
Parameters Used
Bill Factor Based UOM Conversion
BU
Converts a measured quantity into a final quantity using the value specified on a bill factor.
Final Quantity (expressed in the UOM in param 2) =
Quantity for UOM (in param 1) *
Value for Bill Factor (in param 3)
This algorithm would be useful when you need to convert cubic feet (CCF) into therms based on the takepoint from which the premise gets its gas.
Param 1 = Measured UOM
Param 2 = Final UOM
Param 3 = Bill Factor containing conversion factor
Real Time Pricing
RT
Converts a measured quantity (UOM) into a final quantity (Result SQI) by multiplying the measured quantity by the price (Bill Factor) effective on the read's start date/time.
Final Quantity (expressed in the SQI in param 3) =
Value for Real Time Bill Factor (in param 2)
Note, this option is useful if you have simple real time pricing algorithms and do not use the interval billing subsystem. Refer to Pricing Interval Consumption Using Interval Prices for more information.
Param 1 = UOM
Param 2 = Bill Factor
Param 3 = Resultant SQI
Seasonal Register TOU Conversion
ST
Converts time-of-use codes of "current season" and "prior season" to "winter" and "summer" based on the billing period.
Summer Begin Date contains the MMDD when summer starts. Winter Begin Date contains the MMDD when winter starts. Current Season TOU contains the TOU code of the register that measures the current season's consumption. Prior Season TOU contains the TOU code of the register that measures the prior season's consumption. Winter TOU contains the TOU code to be used for winter consumption (the register read's TOU code is changed to this for winter consumption). Summer TOU contains the TOU code to be used for summer consumption (the register read's TOU code is changed to this for summer consumption).
Param 1 = Summer Begin Date (MMDD)
Param 2 = Winter Begin Date (MMDD)
Param 3 = Current Season TOU
Param 4 = Prior Season TOU
Param 5 = Winter TOU
Param 6 = Summer TOU
For more information about defining algorithm types, refer to Setting Up Algorithm Types .
Where Used
A primary Rate Schedule may have zero or more register rules. Refer to Rate Schedule - Register Rules for more information.
