Service XML Viewer
The service XML viewer is an interactive tool that allows you to browse the XML files of service programs that execute on the application server.
You can access the service XML viewer as follows:
• The maintenance object viewer allows you to view the XML file of the maintenance object's service program. This feature is implemented by viewing the maintenance object and then clicking on the
Service XML icon.
• When viewing a maintenance object on the
Maintenance Object page, clicking the
View XML hyperlink causes the service’s XML document to be displayed in the Service XML Viewer.
• When viewing a business service on the
Business Service page, clicking the
• When setting up a
Function, you may want to view the XML document used to pass data to and from the service. Clicking the
View XML hyperlink causes the XML document to be displayed in the Service XML Viewer.
Parent topic
