Oracle Integration Cloud Catalog
Oracle Integration Cloud (OIC) is an offering that serves as integration infrastructure for Oracle cloud solutions. The product provides an adapter for OIC to streamline integration between your edge application and OIC.
The product provides a mechanism (referred to as an adapter) for OIC to retrieve the REST catalog and another to retrieve the SOAP catalog from a given product. The expectation is that a given implementation would use either REST or SOAP and not both, but for those implementations that do support both classes of web services, OIC can retrieve both catalogs.
For the SOAP catalog, the adapter retrieves the name, the source system, the WSDL location and namespace for each web service.
For the REST catalog, the adapter retrieves the name, the source system and the OpenAPI specification for each web service.
It is possible that not every web service supported by an edge product is managed by OIC. In order to only include the appropriate web services in the adapter, configuration is needed to identify which web services to include.
The web service catalog is used to identify the records that should be retrieved by the adapter. Separate catalogs exist for REST and for SOAP
For SOAP inbound messages, the system supports both the use of inbound web services and XAI inbound services that are deployed via IWS. Each IWS or XAI inbound service that should be included in the catalog must be flagged in the SOAP catalog. Note that only deployed services are returned to the catalogue.
For REST inbound messages, each IWS that should be included in the catalog must be flagged in the REST catalog.
For outbound message, the system requires the creation of an External System that includes each outbound message type that the external system receives. For outbound messages that are integrated through OIC, the external system itself will represent OIC. Rather than identifying each outbound message type to include in the catalog, only the external system needs to be flagged. The adapter will return web service information for all the outbound message types configured for the external system. If an implementation supports both REST and SOAP, separate external systems should be created to separately group the REST and SOAP outbound messages.
The subordinate catalog functionality is no longer applicable and will be removed in a future release.
Fastpath:
Refer to Maintaining the Web Service Catalog for more information.
