Create a To Do Entry
In order to create a To Do entry, the system needs to know the To Do type to use. The service accepts a To Do type as input and your XSL that maps data to this service may assign an appropriate To Do type. If you don't pass in a To Do type the system looks up the To Do Type for FA Response indicated on your external system's feature configuration.
