Populating Field Activity Completion
The following table lists the fields to populate for a Field Activity Completion.
FA Upload Staging Information |
FA ID |
All fields in the FA Upload Staging table, FA upload characteristics, FA upload remarks and FA upload staging steps |
"Generic" Step Type Information |
Step Sequence Number |
Customer Contact Info |
Customer Contact Date / Time |
Customer Contact Class |
Customer Contact Type |
Customer Contact Comments |
Meter Information |
Meter Type |
Meter Status |
Manufacturer |
Model |
Serial Number |
Receive Date |
Retirement Date |
Comments |
Retire Reason |
Meter ID Collection |
Meter Characteristics |
Meter Configuration Information |
Effective Date / Time |
Meter Configuration Type |
Register Collection |
Item Information |
Item Type |
Item Status |
Manufacturer |
Model |
Serial Number |
Receive Date |
Retirement Date |
Comments |
Retire Reason Code |
Item Characteristics |
SP Information |
SP Type |
SP Status |
Installation Date |
Out of Service Date |
SP Source Status |
Disconnect Location Code |
Service cycle |
Service Route |
Service cycle / Route Sequence |
Meter Location Code |
Meter Location Details |
Comments |
SP Characteristics |
SP Multi-Item Information |
Effective Date for new collection |
Count of Items |
Item Type Code |
Item Count |
Item Difference. Used to indicate only changes to the existing item count collection. |
Device Test Information |
All fields for main Device Test table |
External System. Used to record a test done by a third party. |
Device Test Component / Result Extra Information. This additional information is used to identify the meter readings that should be associated with component test results that are meter readings. Note. This FA completion service supports providing information for a single meter reading (in the FA upload staging info above). If your device test produces multiple readings, the assumption is that the readings are entered separately prior to this upload of completion information. |
Component sequence. Indicate the sequence of the Device Test Component |
Read Sequence for the register for that component. This should correspond to the register's relative sequence within the meter configuration. |
Component Result sequence. Indicate the sequence of the Component Result |
Read Date/Time. For each result that is related to a meter read, indicate the read date / time so that the system can find the associated meter read for this result. |
