Setting Up Field Activity Remarks
You may link remarks to a field activity using remark codes. To define field activity remark codes, open
Description of Page
Enter a unique Field Activity Remark and a Description for every field activity remark.
Turn on Eligible for Processing if field activities marked with a given remark code should cause one or more algorithm to execute.
The grid contains Algorithms associated with the field activity remark. You must define the following for each algorithm:
- Specify the System Event with which the algorithm is associated (see the table that follows for a description of all possible events).
- Specify the Sequence Number and Algorithm for each system event. You can set the Sequence Number to 10 unless you have a System Event that has multiple Algorithms. In this case, you need to tell the system the Sequence in which they should execute.
The following table describes each System Event.
| System Event | Optional / Required | Description |
| Field Activity Remark Activation | Optional | These algorithms are executed when there are pending FA remarks linked to a field activity and the FACT (Field activity remark activation) background process runs. Refer to Field Activity - Characteristics/Remarks for more information. |
