Service Point - Equipment
The equipment page contains the equipment that is linked to the service point. Use and navigate to the Equipment page. Refer to Equipment May Be Associated With Service Points for more information.
Description of Page
The following fields display:
Equipment ID Indicate the unique equipment identifier. When a piece of equipment is entered, its Badge Number and Equipment Type description are displayed adjacent.
This is actually the ID of an item as an item must be set up for each piece of equipment that can be linked to a service point. Only items with an item type defined on the service point's SP type's equipment collection may be defined (in other words, the valid types of equipment are defined on the service point's SP type).
Equipment Count This field should be 1 except when you are using an item to define a generic piece of equipment. If you use an item to define a generic piece of equipment, you can indicate the number of such generic pieces of equipment that are associated with this service point.
Install Date Define the date that the equipment was installed at the service point.
Removal Date Define the date that the equipment was removed from the service point.
Comment Use comments to explain anything unusual about the piece of equipment.
