Service Points With Multiple Items
An example will help explain a single service point with multiple non-badged items. Assume you have a parking lot with 4 lights, none of which are badged.
You can set up the above example with one premise with a single non-badged service point. On the service point, you create one item for each type of item in the parking lot:
- 20K lumen lamp
- 10K lumen lamp
- pole
For each type of item, you indicate the quantity that exist in the parking lot:
- 20K lumen lamp - 2
- 10K lumen lamp - 2
- pole - 4
Fastpath:
Refer to Service Point - Multiple Items for more information about multi-items on service points.
