FA Log Entry Events
Log entries are generated either manually by a user or via a "plug-in". The system provides some sample plug-ins that may be configured to populate the table.
- The sample FA integration algorithm may be configured to create log entries for certain conditions.
- The sample FA response application services provided by the system create log entries for positive or negative responses to outgoing messages.
- The sample FA completion application service provide by the system may create log entries under certain conditions.
The table below indicates the log types provided by the system and which sample "plug-ins" may create them.
Log Type |
Generated By |
Content of Details |
Appointment Book - Negative Acknowledgement |
FA Response> application service for a negative response to Appointment Book NDS message. |
Negative Acknowledgment. Message ID (%1) - %2. Error (%3) %4 Where %1 is message ID %2 is the Notification Download Type description %3 and %4 are the external message code and its corresponding base message category/number, if the external message code has been specified. |
Appointment Booked |
FA integration algorithm |
Appointment booked for <appointment start date/time > - <appointment end date/time>. |
Appointment Canceled |
Appointment for <appointment start date/time > - <appointment end date/time> has been canceled. |
Appointment Canceled - Negative Acknowledgement |
FA Response application service for a negative response to any Appointment Cancellation NDS message. |
External Message Received |
FA completion application service if action is Update Log |
Message received from %1. Message text: %2 Where %1 is the description of the external system feature configuration %2 is the message sent from the external system. |
FA External ID Change |
FA External ID changed from <FA External ID - Before Change> to <FA External ID - After Change> |
FA Intermediate Status Change |
FA Intermediate Status changed from <Intermediate Status Description - Before Change> to <Intermediate Status Description - After Change> |
FA Status Change |
FA Status changed from <Status Description - Before Change> to <Status Description - After Change> |
Order Cancellation - Negative Acknowledgement |
FA Response application service for a negative response to FA Cancellation NDS message. |
Order Cancellation Confirmed |
FA Response application service for a positive response to FA Cancellation NDS message |
Positive Acknowledgment. Message ID (%1) - %2. Where %1 is message ID and %2 is the description of the NDS type of the original outgoing message. |
Order Change - Negative Acknowledgement |
FA Response application service for a negative response to FA Changed NDS message. |
Order Change Confirmed |
FA Response application service for a negative response to Appointment Book NDS message. |
Order Completion |
FA completion application service |
FA is completed by External System |
Order Creation - Negative Acknowledgement |
Order Creation Confirmed |
Order Reschedule - Negative Acknowledgement |
Order Reschedule Confirmed |
Outage Call Interfaced |
Processing Outage Call NDS message |
Outage call has been sent. |
