TOU Pricing Calc Details - Main
To navigate to this page, you must first go to and display a bill segment with TOU pricing data in its calculation lines. From the Calc Lines tab, you may choose to audit a bill line that is the result of a TOU pricing rate component that has an audit algorithm. Choosing the drill down button for a TOU pricing calculation line takes you to the TOU Pricing Calc Details - Main page.
Description of Page
Refer to Interval Pricing Details - Main for information about the information displayed in the top portion of the page. The one difference with the information displayed on this page is that the Quantity Billed includes the description of the time-of-use code along with the UOM and SQI.
The TOU Consumption Graph displays in Red the interval quantities that were mapped to the time-of-use code represented by the line. The Y-axis shows the range of values plotted under the column UOM. The X-axis shows the date for each interval.
Refer to Interval Pricing Details - Main for information about drilling down into the graph.
