Core Control Table Setup Sequence
To implement the system, you must set up your organization's business rules in "control tables". Setting up these tables is time-consuming because we allow you to tailor many aspects of the system to meet your organization's requirements. We strongly recommend that you take the time to document how you plan to set up all of these tables before you use the following roadmap to enter the core control data. Time spent understanding the interrelationships between this data will reap the rewards of a clean system that meets your current and long term needs.
While we describe the transactions and options in more detail in other sections of this manual, use the following chart (and the remaining sections of this chapter) as your roadmap. Here we list the order in which you perform tasks and the pages you'll use to set up your system. The order is important because some information must exist before other information can be defined (i.e., many dependencies exist).
Function |
Menu |
Auto Setup |
Global Context |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that populates global context values. The global context is used by various zones in the system to display relevant data. This algorithm is plugged-in on the installation record. |
Accounting Environment |
Country & State |
Admin, Country |
Currency Codes |
Admin, Currency Code |
USD is automatically populated |
Accounting Calendar |
Admin, Accounting Calendar |
GL Division |
Admin, General Ledger Division |
Security Environment |
Application Service |
Admin, Application Service |
All base package transactions are automatically populated |
Security Type |
Admin, Security Type |
User Group |
Admin, User Group Note, you won't be able to set up users at this point |
One user group, ALL_SERVICES, is automatically setup. It references all other application services and a single user called SYSUSER. Note:
The SYSUSER used is provided for use with on-premises
implementations. It is disabled by default in cloud service
implementations. |
Language |
Admin, Language |
ENG is automatically populated |
Display Profile |
Admin, Display Profile |
Two display profiles are automatically setup: NORTHAM displays currencies and dates in a classic American format; EURO displays information in a classic European format |
Data Access Role |
Admin, Data Access Role |
Access Group |
Admin, Access Group |
User |
Admin, User |
SYSUSER is automatically set up. Note that you may import your users (and user groups) from an external source. |
Return to User Group |
You must return to your user groups and define all of their users |
Customer Class Environment |
Customer Class |
Admin, Customer Class. At this point, you'll only be able to set up your customer class codes. You will return to these customer classes throughout the setup process to populate additional information. |
Financial Transaction Environment |
Work Calendar |
Admin, Work Calendar |
CIS Division |
Admin, CIS Division |
Revenue Class |
Admin Revenue Class |
Algorithm |
Admin, Algorithm. You will need to set up the algorithm that constructs a distribution code's corresponding GL account when it is interfaced to the general ledger |
Distribution Code |
Admin, Distribution Code |
Bank & Bank Accounts |
Admin, Bank |
Billable Charge Template |
Admin, Billable Charge Template. Note, if you want the system to default service quantities onto billable charges created using this template, you must setup the appropriate unit of measure code, time-of-use code and/or service quantity identifier. |
Billable Charge Upload Line Type |
Admin, Billable Charge Line Type |
Algorithm |
Admin, Algorithm. You will need to set up several algorithms. These algorithms: 1) retrieve a bill segment's consumption, 2) calculate a bill segment's bill lines, 3) construct a bill segment's financial transaction, 4) cancel previously estimated bill segments |
Bill Segment Type |
Admin, Bill Segment Type |
Algorithm |
Admin, Algorithm. You may want to set up an algorithm that formats the Bill Segment information that is displayed throughout the system for a specific Bill Segment Type. This algorithm is plugged-in on the Bill Segment Type. |
Algorithm |
Admin, Algorithm. You will need to set up the algorithm that constructs a payment segment's financial transaction |
Payment Segment Type |
Admin, Payment Segment Type |
Algorithm |
Admin, Algorithm. You will need to set up the algorithm that constructs an adjustment's financial transaction |
Algorithm |
Admin, Algorithm. Several plug-in spots are available to perform additional logic when processing adjustments. For example, if you have the system calculate adjustments, you must set up an adjustment generation algorithm. Refer to Adjustment Type for other available plug-in spots that may be used by your implementation. |
Algorithm |
Admin, Algorithm. You may want to set up an algorithm that formats the Adjustment information that is displayed throughout the system for a specific Adjustment Type. This algorithm is plugged-in on the Adjustment Type. |
Algorithm |
Admin, Algorithm. You may want to set up an algorithm that formats the Adjustment information that is displayed throughout the system. This algorithm is plugged-in on the installation record. |
Adjustment Type |
Admin, Adjustment Type |
Adjustment Type Profile |
Admin, Adjustment Type Profile |
Approval Profile |
Admin, Approval Profile. Note, an approval profile references a To Do type and one or more To Do Roles; these must be set up before you can set up the approval profile. After the approval profile(s) are set up, they must be referenced on the adjustment types that they govern. |
Cancel Reason - Bill |
Admin, Bill Cancel Reason |
Cancel Reason - Payment |
Admin, Payment Cancel Reason |
Cancel Reason - Adjustment |
Admin, Adjustment Cancel Reason |
Tender Type |
Admin, Tender Type |
Tender Source |
Admin, Tender Source |
A/P Request Type |
Admin, A/P Request Type |
Issuing Center |
Admin, Issuing Center. You will need to set up issuing centers if your organization assigns document numbers to bills. |
Installation |
Admin, Installation Options - Framework and Admin, Installation Options. Many fields on the installation record impact the financial transaction environment. Refer to the description of the Billing and Financial Transaction pages and the Messages tab in the Framework page for more information. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that distributes payments. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that handles overpayment situations. |
Algorithm |
Admin, Algorithm. You may need to set up an algorithm if specific customers can have individual bill due dates. |
Algorithm |
Admin, Algorithm. You may need to set up an algorithm if you want the system to delete bills that contain only information about historical payments. |
Algorithm |
Admin, Algorithm. You may need to set up an algorithm if you want the system to levy a non-sufficient funds charge if a payment is canceled due to non-sufficient funds. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that formats the bill information that is displayed throughout the system. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that formats the payment information that is displayed throughout the system. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that defaults the amount when a payment is manually added. This algorithm also calculates the amount of an automatic payment for a bill for an account with an active auto pay option. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. Refer to Customer Class for other available plug-in spots that may be used by your implementation to perform additional logic when processing payments and bills. |
Return to Customer Class |
Admin, Customer Class. You will need to plug-in the algorithms defined above on your customer classes. |
Budget Environment |
Algorithm |
Admin, Algorithm. You will need to set up several algorithms at this time: How To Calculated The Recommended Budget Amount, How To Periodically True Up A Customer's Budget Amount, The Circumstances When The System Should Highlight A Customer As Having An Anomalous Budget. |
Budget Plan |
Admin, Budget Plan |
Algorithm |
Admin, Algorithm. Budget eligibility is set at the SA type level. You will need to set up an override budget eligibility algorithm if some service agreements for an SA type are not eligible for budget based on certain conditions. |
Customer Environment |
Account Management Group |
Admin, Account Management Group. Note, you will probably have to set up To Do Type and To Do Roles before you can setup account management groups. Refer to Assigning A To Do Role for more information on how account management groups may be used to define an entry's role. |
Account Relationship |
Admin, Account Relationship Type |
Alert Type |
Admin, Alert Type |
Bill Message |
Admin, Bill Message |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a bill in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your bill image software. |
Bill Route Type |
Admin, Bill Route Type |
Contract Quantity Type |
Admin, Contract Quantity Type |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a letter in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your letter image software. |
Letter Template |
Admin, Letter Template |
Customer Contact Class |
Admin, Customer Contact Class |
Customer Contact Type |
Admin, Customer Contact Type |
Conservation Programs |
Admin, Conservation Program. You will need to set up conservation programs if your organization provides rebates to customers based on eligibility and verification of newly purchased appliances and hardware that are rated to conserve the demand for energy. |
Algorithm |
Admin, Algorithm. You may need to set up the algorithms that determine if person ID's are in a predefined format. |
Person Identifier Type |
Admin, Person Identifier Type |
SICs |
Admin, SIC Code |
Tax Exempt Type |
Admin, Tax Exempt Type |
Algorithm |
Admin, Algorithm. You may need to set up the algorithms that determine if phone numbers are in a predefined format. |
Phone Type |
Admin, Phone Type. |
Person Relationship Type |
Admin, Person Relationship Type. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that formats the person information that is displayed throughout the system. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm to validate a person's name. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You can override the system's standard account information string by setting up an algorithm that produces this string of information. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a letter in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a bill in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record. |
Installation |
Admin, Installation Options. Many fields on the installation record impact the Customer Environment. Refer to the description of the Main, Person, and Account tabs for more information. |
Statements |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a statement in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your statement image software. |
Statement Route Type |
Admin, Statement Route Type |
Statement Cycle |
Admin, Statement Cycle |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a statement in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record. |
Automatic Payment (EFT) Environment |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm to create automatic payments. This algorithm is plugged-in on the installation record. |
Tender Source |
Admin, Tender Source Note: earlier, you created tender sources for the remittance processor and your cash drawers. At this point, you'll need to add at least one tender source for automatic payments. Why? Because automatic payments get linked to a tender control (which, in turn, gets linked to a tender source) when they are interfaced out of the system. |
Algorithm |
Admin, Algorithm. You will need to set up the appropriate automatic payment date calculation algorithm to populate the extract, GL interface and payment dates on automatic payments. |
Auto Pay Route Type |
Admin, Auto Pay Route Type |
Tender Type |
Admin, Tender Type Note: earlier, you created tender types for things like cash, checks, etc. At this point, you'll need to add a tender type for each type of automatic payments (e.g., direct debt, credit card, etc.). |
Work Calendar |
Admin, Work Calendar. You need only set up additional work calendars if the auto pay sources (i.e., the financial institutions) have different working days than does your organization |
Algorithm |
Admin, Algorithm. If you need to validate the customer's bank account or credit card number, you will need to set up the appropriate validation algorithms. |
Auto Pay Source Type |
Admin, Auto Pay Source Type |
Algorithm |
Admin, Algorithm. You may need to set up an algorithm if your customers can define a maximum withdrawal limit on their autopay options. |
Admin, Customer Class. You should plug-in the Autopay Over Limit Algorithm in each appropriate customer class. |
Deposit Environment |
Algorithm |
Admin, Algorithm. You will need to set up several algorithms at this time: The Definition Of A Good Customer, When To Refund A Deposit To A Customer, When To Recommend An Additional Deposit, How / When To Calculate Interest, How To Generate The Recommended Deposit Amount. |
Deposit Class |
Admin, Deposit Class |
Non Cash Deposit Type |
Admin, Non Cash Deposit Type |
Field Work Environment - Phase 1 |
Representative |
Admin, Representative |
Operation Area |
Admin, Operation Area |
Field Service Class |
Admin, Field Service Class |
Algorithm |
Admin, Algorithm. You will need to set up the algorithms that execute special functions (if any) when a field activity is completed |
Field Activity Type & Steps |
Admin, Field Activity Type |
Field Activity & Field Order Cancellation Reason |
Admin, Fieldwork Cancel Reason |
Field Activity & Field Order Reschedule Reason |
Admin, Fieldwork Reschedule Reason |
Algorithm |
Admin, Algorithm. If you need anything special to happen when a remark is associated with a field activity (e.g., generate a To Do), you will need to set up an algorithm to do whatever you need to do and associate it with the respective Field Activity Remark. |
Field Activity Remarks |
Admin, Field Activity Remark |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a field order in a PDF (for the purpose of online display), you will need to create an algorithm that formats the extract records that are sent to your field order image software. |
Dispatch Group |
Admin, Dispatch Group |
Disconnect Location |
Admin, Disconnect Location |
Field Activity Type Profiles |
Admin, Field Activity Type Profile |
Algorithm |
Field activities for Start/Stop will only be created if the SA Type linked to the service point has a SASP field work creation algorithm. Refer to the SA Type section below. |
Algorithm |
Admin, Algorithm. If you have software that's capable of reconstructing an image of a field order in a PDF for the purpose of online display, you will need to create an algorithm that renders this PDF. This algorithm is plugged-in on the installation record. |
Credit & Collections Environment (if you collect on overdue bills (as opposed to overdue debt), you will NOT set up these tables; refer to Overdue Processing - Set Up Tasks for the list of control tables required to collect on overdue bills) |
Algorithm |
Admin, Algorithm. You may need to set up algorithms if you have non-standard collection events. |
Collection Event Type |
Admin, Collection Event Type |
Algorithm |
Admin, Algorithm. You may need to set up a collection process cancellation algorithm if your organization allows individual service agreements to be removed from a collection process if they are paid (rather than performing cancellation based on all SAs in a debt class). |
Collection Process Template |
Admin, Collection Process Template |
Collection Class |
Admin, Collection Class |
Algorithm |
Admin, Algorithm. You will need to set up several algorithms at this time: Collection process cancellation criteria, Severance process cancellation criteria, and Override arrears due to pay plans. |
Debt Class |
Admin, Debt Class |
Write Off Debt Class |
Admin, Write Off Debt Class |
Algorithm |
Admin, Algorithm. You will need to set up Collection Condition algorithms. |
Collection Class Control |
Admin, Collection Class Control |
Algorithm |
Admin, Algorithm. You may need to set up algorithms if you have non-standard severance events. |
Severance Event Type |
Admin, Severance Event Type |
Algorithm |
Admin, Algorithm. You may need to set up a severance process cancellation algorithm if your organization allows a severance process to be canceled when the related service agreement is paid (rather than performing cancellation based on all SAs in a debt class). |
Severance Process Template |
Admin, Severance Process Template |
Algorithm |
Admin, Algorithm. You will need to set up several algorithms at this time: How to refer debt to a collection agency, How to transfer debt to another active service agreement, How to write down small amounts of debt, and How to refund credit balances to a customer. |
Algorithm |
Admin, Algorithm. You may need to set up algorithms if you have non-standard write-off events. |
Write Off Event Type |
Admin, Write Off Event Type (Note, you'll have to wait until you have defined your SA Types before you can set up the Write Off Events because SA Type is a necessary parameter to write off debt). |
Write Off Process Template |
Admin, Write Off Process Template |
Write Off Control |
Admin, Write Off Control |
Collection Agency |
Admin, Collection Agency. Note, each collection agency references a person therefore you must set up a person for each agency before you can enter collection agency information. |
Algorithm |
Admin, Algorithm. You may need to set up algorithms if you have special logic that should be executed when a pay plan is canceled. |
Pay Plan Type |
Admin, Pay Plan Type |
Payment Method |
Admin, Payment Method |
Third Party Payor |
Admin, Third Party Payor. Note, you must create an account before you can create a third party payor. |
Installation |
Admin, Installation. Several fields on the installation record impact the Credit & Collections Environment. |
Algorithm |
Admin, Algorithm. You will need to setup an algorithm that's called when a user write-off debt real time. |
Services & Characteristics |
Service Type |
Admin, Service Type |
Algorithm |
Admin, Algorithm. If you have ad hoc characteristic types, you may need to set up the algorithms that control how they are validated |
Foreign Key Reference |
Admin, FK Reference. If you have foreign key characteristic types, you may need to set up foreign key references to control how the user selects the characteristic values (and how the foreign key values are validated). |
All base package FK references are automatically populated |
Characteristic Type & Values |
Admin, Characteristic Type |
Device Testing Environment |
Algorithm |
Admin, Algorithm. If you need to validate a specific device test component result, you will need to set up the appropriate validation algorithms. |
Device Test Component Type |
Admin, Device Test Component Type |
Algorithm |
Admin, Algorithm. If you need the system to determine if a device test's results are considered "passing", you will need to set up an algorithm to perform this processing. |
Device Test Type |
Admin, Device Test Type |
Algorithm |
Admin, Algorithm. If you have the system select meters / items for testing, you will need to set up an algorithm to perform this processing. |
Meter & Item Environment |
Meter Type |
Admin, Meter Type [Note - you won't be able to define the collection of valid Equipment Types and Item Types until after you define the Item Types. You also will not be able to define the collection of Meter Configuration Types until after you define the Meter Configuration Types.] |
Meter ID Type |
Admin, Meter ID Type |
Manufacturer / Model |
Admin, Manufacturer |
Unit of Measure |
Admin, Unit of Measure |
Time of Use |
Admin, Time of Use |
Meter Configuration Type |
Admin, Meter Configuration Type |
Retirement Reason |
Admin, Retire Reason |
Protocol |
Admin, Protocol |
Read Out Type |
Admin, Read Out Type |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm to generate estimated consumption. |
Trend Area |
Admin, Trend Area |
Trend Class |
Admin, Trend Class |
High / Low |
Admin, High Low Factor |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that calculates the high / low limits used on meter reads. This algorithm is plugged-in on the installation record. |
Meter Location |
Admin, Meter Location |
Meter Read Instructions |
Admin, Meter Read Instruction |
Algorithm |
Admin, Algorithm. If you need anything special to happen when a meter read with a given remark is uploaded (e.g., generate a field activity), you will need to set up an algorithm to do whatever you need to do and associate it with the respective Meter Read Remark. |
Meter Reader Remarks |
Admin, Meter Reader Remark |
Meter Read Source |
Admin, Meter Read Source |
Meter Read Warning |
Admin, Meter Read Warning |
Item Type |
Admin, Item Type |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm to format the standard meter info that appears throughout the system. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm to format the standard item info that appears throughout the system. This algorithm is plugged-in on the installation record. |
Premise & Service Point Environment |
Premise Type |
Admin, Premise Type |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm to format the standard premise info that appears throughout the system. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You will need to set up an algorithm that formats the service point information that is displayed throughout the system. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You may need to set up the algorithms that determine if geographic ID's are in a predefined format. |
Geographic Type |
Admin, Geographic Type |
Service Point Type |
Admin, SP Type. [Note - you won't be able to define the SP Type's SA Types until after you define the SA Types or the FA Type Profiles until after you define the Field Activity Type Profiles.] |
Facility Level 1 to 2 |
Admin, Facility Level 1 to 2 |
Facility Level 2 to 3 |
Admin, Facility Level 2 to 3 |
Field Work Environment - Phase 2 |
Field Service Control |
Admin, Field Service Control |
Bill & Service Cycle Environment |
Bill Cycle, Bill Cycle Schedule |
Admin, Bill Cycle |
Bill Period, Bill Period Schedule |
Admin, Bill Period |
Route Type |
Admin, Route Type |
Service Cycle / Route |
Admin, Service Cycle |
Service Schedule |
Admin, Service Schedule |
Rate Environment |
Frequency |
Admin, Frequency |
Service Quantity Identifier |
Admin, Service Quantity Identifier |
Algorithm Type |
Admin, Algorithm Type. If you create new pre-processing calculation rules, you must set up an algorithm type for each such rule (the algorithm type defines the types of parameters that are passed to the calculation rule). |
All base package algorithm types are automatically populated |
Bill Factor |
Main, Rates, Bill Factor |
Algorithm Type |
Admin, Algorithm Type. If you create new Register Rules you must set up an algorithm type for each such rule (the algorithm type defines the types of parameters that are passed to the register rule). |
Rate |
Main, Rates, Rate Schedule |
Calculation Group |
Main, Rates, Calculation Group |
Algorithm |
Admin, Algorithm. If you use algorithms to dynamically change step boundaries, calculate prices, or implement calculation rule eligibility rules, you must set up these algorithms. |
Calculation Rule |
Main, Rates, Calculation Rule |
Bill Factor Value |
Main, Rates, Bill Factor Values |
Bill Factor Interval Values |
Main, Rates, BF Interval Values |
Item Type SQ Estimate |
Admin, Item Type SQ Estimate |
Degree Day |
Admin, Degree Days |
Late Payment Environment |
Algorithm |
Admin, Algorithm. You will need to set up the algorithm that determine if customers in a customer class are eligible for late payment charges |
Algorithm |
Admin, Algorithm. You will need to set up the algorithm that levies late payment charges for customers in a customer class |
Admin, Customer Class. You will need to plug-in the late payment charge algorithms set up above. |
SA Configuration |
Algorithm |
Admin, Algorithm. You will need to set up the algorithms that determine: • How to calculate the late payment charge amount for service agreements of a given type • Special criteria to be tested before a service agreement is severed. • How to create field activities for service agreements of a given type. • Special processing that should take place prior to the completion of a bill that references service agreements of a given type. • Special processing that should take place during completion of a bill that references service agreements of a given type. • Special processing that should take place when service agreements of a given type are created. • Special processing that should take place when a financial transaction is frozen for service agreements of a given type. |
Algorithm |
Admin, Algorithm. You may want to set up an algorithm that formats the SA information that is displayed throughout the system. This algorithm is plugged-in on the installation record. |
Algorithm |
Admin, Algorithm. You may want to set up an algorithm that formats the SA information that is displayed throughout the system for a specific SA Type. This algorithm is plugged-in on the SA Type. |
Algorithm |
Admin, Algorithm. If you want a Control Central alert to highlight when the current account has any stopped service agreement(s), you will need to set up the algorithm that does this. This algorithm is plugged-in on the installation record. |
Service Agreement Type |
Admin, SA Type |
Terms and Conditions |
Admin, Terms and Conditions |
SA Type Start Options |
Admin, SA Type Start Option |
Update SP Types with initial SA types and with FA Type Profiles |
Admin, SP Type |
SA Relationships |
SA Relationship Type |
Admin, SA Relationship Type |
Service Provider |
Admin, Service Provider. Note, you must create a person before you can create a service provider. If you have financial relationships (you bill for them or they bill for you), you must also create an account and a financial settlement service agreement before you can create the service provider. |
SA Type / SA Relationship |
Admin, SA Type SA Relationship Type |
Notification and Workflow |
Workflow Event Type |
Admin, Workflow Event Type |
Workflow Process Template |
Admin, Workflow Process Template |
Notification Upload Type |
Admin, Notification Upload Type |
Workflow Process Profile |
Admin, Workflow Process Profile |
Notification External (Sender) ID's |
Admin, Notification External ID |
Notification Download Type |
Admin, Notification Download Type |
Service Provider. |
Admin, Service Provider. Note, you must create a person before you can create a service provider. |
Notification Download Profile |
Admin, Notification Download Profile |
Algorithm |
Admin, Algorithm. If you want a Control Central alert to highlight when the current account and/or premise has active workflow processes, you will need to set up the algorithm that does this. This algorithm is plugged-in on the installation record. |
Sales and Marketing |
Order Hold Reason |
Admin, Order Hold Reason |
Order Cancel Reason |
Admin, Order Cancel Reason |
And more... |
Refer to Campaign and Package Setup Sequence for additional setup requirements |
Service Credit Membership |
Algorithm |
Admin, Algorithm. You may need to set up algorithms for the service credit membership type and service credit event type to control behavior for the service credit membership and its events. |
Credit Unit |
Admin, Credit Unit. If your service credits record non-monetary units. |
Service Credit Membership Type |
Admin, Service Credit Membership Type |
Service Credit Event Type |
Admin, Service Credit Event Type |
Membership Inactive Reasons |
Admin, SC Membership Inactive Reason |
Wrap Up |
Algorithm |
Admin, Algorithm. You will need to set up the algorithms that determine: #x2022; Special alerts on Control Central (assuming you have special alerts) |
Installation Options |
Admin, Installation Options - Framework and Admin, Installation Options. At this point, it's a good idea to double-check everything on the installation record. |
Postal Default |
Admin, Postal Code Default |
If you have cash drawers you will also need to set up the following information:
- Create a person / account to which you will link your over / under service agreement. Refer How To Get An Unbalanced Tender Control In Balance (Fixing Over/Under) for more information.
- Create a service agreement to which your over/under payments will be linked. This service agreement will reference your over / under SA type. Refer to Over / Under Cash Drawer Segmentation for more information.
If you upload payments from an external source (e.g., a remittance processor or lock box), you must set up the following information:
- Create a person and account to which the system will link payments with invalid account. Refer to Phase 3 - Create Payment Events, Tenders, Payments and Payment Segments for information about the process that books invalid payments to this account. Refer to How To Transfer A Payment From One Account To Another for how a user transfers the payment from the invalid account to the correct account (once known).
- Create a service agreement for this account. This service agreement will reference your payment suspense SA type. The system needs this service agreement so that it can distribute the invalid account's payment (and this is necessary so that cash will reflect the payment). Refer to Payment Upload Error Segmentation for more information.
- Update the tender source associated with the respective source of payments to indicate the service agreement created in the previous step should be used for payments with invalid accounts. Refer to Setting Up Tender Sources for more information.
- Because the payment upload process simply books payments that reference invalid accounts to the account associated with the suspense service agreement on the payment's tender source, this account should belong to a customer class with the appropriate payment distribution algorithms. This may entail creating a new customer class that will only be used on suspense accounts. This customer class would need the following algorithms:
- We'd recommend using a simple payment distribution algorithm like PYDIST-PPRTY (distribute payment based on SA type's payment priority).
- We'd recommend using an overpayment distribution algorithm like OVRPY-PPRTY (distribute overpayment to highest priority SA type).
The remaining sections describe additional control tables that must be set up for specific functional areas.
