Determine If Any Properties Are Overridden On Any Package
At this point, you have defined the properties of all miscellaneous fields at the campaign level. You now need to determine if any of your packages need to override any of these properties. In general, you can only override miscellaneous fields whose campaign applicability is optional or only applicable on package(s).
Our example campaign has only two overrides:
Package 1 requires the following miscellaneous field overrides:
Misc. Field |
Override Prompt (seen if a package is selected) |
Override Package Applicability |
Override Default Value |
Date of birth |
Not overridden |
Required |
Not overridden |
Package 4 requires the following miscellaneous field overrides:
Misc. Field |
Number of Units in House |
Not overridden |
Required |
2 |
If you override field properties on a campaign's packages, you will not be able to change the properties of the field at the campaign level.
